Old 10-05-2009, 08:28 AM   #1
gcunha
Rust Proofing
Would anyone know where;s the best place for Rust proofing.
gcunha is offline   Reply With Quote
Old 10-05-2009, 09:13 AM   #2
slemmer
Driving in the fast lane
slemmer's Avatar
What kind of treatment are you looking for - oil spray, full spray, etc.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 10-05-2009, 09:16 AM   #3
gcunha
I'm not sure what's best, therefore the reason of my post. I have a 2005 645 CI. no rust yet, nut I'm planning to keep this car for a while. I've heard of some yellow stuff, that is pretty good.
Thanks for your reply.
Old 10-05-2009, 09:57 AM   #4
330Hi
330Hi's Avatar
I always go to RushCheck at Richmond Hill. I've been going there for about 4 years now.
The owner there gives me a good deal. I've had over 15 cars rust proofed over there (including my friends')
Take this flyer with you. Talk to Hass or Maalik. Tell him the guy with the M3 sent you. He'll take care of you!
330Hi is offline   Reply With Quote
Old 10-06-2009, 07:28 PM   #5
Marky_mark
Detailing Specialist
Marky_mark's Avatar
Ziebart has the best rust proofing they don't drill any holes in you car which is a good thing I get my car done by them its dripless also unlike like rust check and krown oil spray. The one you want from Ziebart is the Penetr-Oil dripless oiling process
Old 10-20-2009, 02:22 PM   #6
2009323i
is it worth oil spraying Bimmers? I have an 2009 and live in ottawa. I have a specv last that i oil sprayed at krown for like 3 out of 6 years and it started to rust where they drilled. Also I hate when the under the hood is all greasy. BMW told me not to since it has 12 year warranty. Just not too sure what too do
2009323i is offline   Reply With Quote
Old 11-02-2009, 02:40 PM   #7
318compact
I'm new on this forum, but pretty experienced when it comes to rustproofing. Rustproofing is only worth your while if you plan to keep the car beyond age 10 or so. If you keep your car clean and wash the underside thouroughly every spring, there should not be any rust on a BMW, rustproofed or not if it is 10 or younger. However, if you take a look at a 15 year old car, the one that was rustproofed regularly will be in a lot better shape. So if you invest in rustproofing, don't expect the "payout" before at least a decade of use. In my opinion, the thin dripping oil-based rustproofing works best, although it has to be applied at least every other year. I don't trust wax based rustproofing, seems to seal the elements out but the metal can still rust underneath without being noticed until its too late to do anything about it. I did not have ANY holes drilled in my car, you can access all the cavities you need through factory openings if you know where to look for them. I have not found any shops that do yet, so I have to show them around the car while they bust my b.lls for not allowing them to just drill holes which is so much easier for them.
318compact is offline   Reply With Quote
Old 11-13-2009, 01:39 AM   #8
just got mine done at Rust Check in Brampton. Opted for the drip-less gel and only got the under carriage and wheel wells done, did not want them to drill holes.
Old 11-14-2009, 02:37 AM   #9
iverson03tj
iverson03tj's Avatar
do you guys know what they call those thick rust proofing thing, its like foam, and it stays on ur car for like ever. It think n grey and feels kinda like sponge?
Old 11-15-2009, 09:30 PM   #10
BmW1819
yea iam in the same room i don't no where to go
Old 11-16-2009, 01:33 AM   #11
W2WDETAILING
im going to get my jeep done at ziebart just down the street from eglington and laird... ive been reasearching and i have been hearing good things about ziebart
Old 11-16-2009, 09:12 PM   #12
BmW1819
what do they use??? and i hope they don't bomb the shit of everything like the bushings
Old 11-16-2009, 09:46 PM   #13
W2WDETAILING
PENETR-OIL® DRIPLESS OILING PROCESS FROM $109.00
• Annual, dripless oiling process penetrates all seams and joints, displaces moisture.
• Inhibits existing rust and prevents new rust for a full year.
• Coats and penetrates without continued, messy dripping.
• Your entire vehicle is oiled while you wait and ready to go in 1-2 hours.
• Designed for new or used cars, trucks, vans, and sport utility vehicles.
• Offers you the flexibility of annual protection on a pay-as-you go basis.
• Dripless process is cleaner and less harmful to the environment.
• Satisfaction is guaranteed!
http://www.ziebarttoronto.com/protection.htm
im going to check them out on thursday after work
Old 11-19-2009, 12:05 AM   #14
iverson03tj
Let us know if they did a good job and if they drilled any holes.
Old 12-03-2009, 10:52 PM   #15
BmW1819
did they drill at ziebart?? i sprayed my own car with rustcheck at canadian tire took out the orignal caps in the door and bomb them all the under body only costs me 40$ 4 cans not and sprayed where e36 like to rust
