Welcome to!
Old 10-02-2009, 01:00 PM   #1
FS:BNIB Optima Yellow Top Battery
I have a brand new still in plastic Optima Yellow Top 34DU Battery for sale.
I am asking $180 FIRM. I will not budge on the price since this battery sells for $200+ in the stores.
It comes with full warranty from Interstate.
The SC34DU YellowTop high-performance AGM battery is one of the only true dual-purpose automotive batteries available. With premium cranking power and unparalleled cycling capability (rechargeability), it is perfect for modern accessory-loaded vehicles. The YellowTop can repeatedly bounce back from deep power drains to full energy capacity, so it can power plenty of electronics and still start you up time after time. Lower internal resistance also provides more consistent power output and faster recharges.
• Up to 2x longer life
• More than 15x the vibration resistance
• Completely spill-proof mountable in many positions
• Maintenance free
• Faster recharging capabilities
• Optimal starting power, regardless of temperature
• Voltage: 12V
• CCA (Cold Cranking Amps @ 0F): 750
• CA (Cranking Amps @ 32F): 870
• Reserve Capcity: 120
• Capacity (C/20 Rate): 55
• Internal Resistance (ohms): 0.0028
Physical Spec
• Dimensions (LxWxH): 10 x 6 7/8 x 7 13/16 inches
• Minimum Weight (lbs): 43.5
• Type Post/Terminal: Dual SAE & GM
• BCI Group: 34/78
** E70 X5 4.8 **
rudetrini is offline   Reply With Quote
Old 10-02-2009, 07:09 PM   #2
bimmerjoe's Avatar
the best battery i ever purchased!!
1999 323i-sold
2001 540i M- Sport
bimmerjoe is offline   Reply With Quote
Old 10-03-2009, 02:29 PM   #3
spoony_prelude's Avatar
+1! I can have my music on (with subs pounding) while doing a 2hour car wash, when I'm done, car starts perfectly!
2011 M3 coupe/moonstone/fox red
Old 10-03-2009, 03:38 PM   #4
Ahctuning's Avatar
How good is this battery compared to the green/white one? I can get the Interstate battery for $147 at MetroSquare.
Ahctuning is offline   Reply With Quote
