Old 09-04-2009, 12:01 PM   #1
jiggatwist
Guages Bottom Out and Lights go Out!?
Hi All,
last night driving home from work my guages on the dash all dropped to the negative, like, temp guage to zero, speedo to zero, fuel to zero, tach to zero. and the lights within the dash went out aswell.
2-3 seconds later everything came back to normal.
this has happend 1-2 weeks ago once before, anyone experiece this before or have an idea what it might be?
Thanks,
jiggatwist is offline   Reply With Quote
Old 09-04-2009, 01:34 PM   #2
MiroE36
MiroE36's Avatar
your car got scared of something so it played dead.
Old 09-04-2009, 03:05 PM   #3
Allstar_e36
Allstar_e36's Avatar
Do you have aftermarket headlights? are you running HID's? if so it could be from the headlights. its happened to a couple of ppl on bimmerforums, might wanna search there.
Allstar_e36 is offline   Reply With Quote
Old 09-04-2009, 11:03 PM   #4
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Check the bundle of wires that passes through the trunk lid. Over time the insulation wears off and shorts and causes all sorts of weird electrical issues.
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 09-05-2009, 12:40 PM   #5
nachos23
SweetXi
nachos23's Avatar
I'd suggest a bad connection likely in @ one end of the connector (could be either end). Check the cable bundle for fraying of wires and to ensure non of the insulation has come off (shorting to ground), or given the age of your car, I'd also look for bad connectors @ both ends. Disconnect and physically inspect the connections. SPray all connectors with WD-40 or similar product to remove any rust that could be causing the bad connection....
Old 09-06-2009, 01:18 AM   #6
jasonlau8023
this happened to me before.
check your fuse box and make sure fuses are working fine.
jasonlau8023 is offline   Reply With Quote
