Old 09-03-2009, 11:47 AM   #1
ecuconnection
ecuconnection's Avatar
Luskville Cruise - Sept 12 2009
Meet in Kanata at the Tim Hortons at Carling & March Rd 12:00 Noon
Cruise to the ferry and continue to luskville
Ferry = $7
Unlimted Run's = $25
There is only a few more weeknds left befor it closes so this would be a good time to go
Bring Your chair... Hopefully Mike can get the autovations tent
Who is in?
Old 09-03-2009, 12:36 PM   #2
Won't know for a little bit if I'm busy sat or sunday. Hopefully I can go.
Old 09-03-2009, 04:12 PM   #3
bmdbley'sBro
wouldu like some tinfoil?
bmdbley'sBro's Avatar
would've loved to but my car is legendary jokes when it comes to running reliably!
H/G just let go (tues), overheated with an air lock (no heat out of dash) & white smoke pouring out my tailpipe
i'd be mad, but turboready will be shoving in a Ringed m42, head with 3 angle valve job, with megasquirt
car is already there.
Old 09-03-2009, 04:34 PM   #4
What kind of boost were you running? Did you have a wideband?
Just trying to figure out why you'd push a HG since I thought you were running about 8psi. It all comes down to cylinder pressure (too much spark advance) or EGT (lean fuel).
Megasquirt should fix that all up though!
Old 09-03-2009, 07:02 PM   #5
ecuconnection
He was on stock ign timing and at 10psi I had to start pulling timing so I'm going to guess he was spiking over 10
Old 09-03-2009, 08:59 PM   #6
Yet stock timing at 10psi = bad. Rule of thumb is you'd need about 10 degrees of retard. It would need to be carefully tuned at that range.
What octane of fuel do you guys run? I always run 93 Stinson's (excellent) or Sunoco Ultra 94.
Old 09-03-2009, 10:36 PM   #7
carjoe
carjoe's Avatar
Crap. I gotta help someone move that day. I'd love to go at least once with the E39...
93 325is - sold!
2000 540ia- sold!
Old 09-04-2009, 01:05 AM   #8
ecuconnection
luckly I got my hands on the dinan NA tune to compare and made things alot easyer when tuning ... at 17psi I'm at 15degs for best power
Old 09-05-2009, 06:05 PM   #9
bmdbley'sBro
on the stock h/g's (been through 2 now) i was running upto 12lbs. spiking upto 17+ or so the max saved reading on the gauge said then afte 5K usage my 2nd factory h/g went, then D.bag in qc had my car 7months (I feel i was the victim of fraud). then striker was within 1K was fixing coolant & boost/vacume leaks, some loose interior seal inside my head (visible from oil filler opening) type work/slash non work.
also had to deal with stripped valve cover screws courtesy of mr D.bag.
its amazing i got this far
wish i had known that. amazing i didn't blow up sooner
sick man, i will need a ride in that before winter. yours too everlast
and yeah when you machine down the top of a block beside the pistons & ring them with bronze or copper is that 'ringing' or 'sleaving' ?
Old 09-07-2009, 01:01 AM   #10
ecuconnection
I have to cancel on this ... something came up ... sorry folks
