Old 08-23-2009, 03:19 PM   #1
FLIPbmw
Painting tip, need help
I'm painting up some spots on my fender and hood. I've been sanding the bondo and primer up to 1000grit. My paint is a laguna green metallic. I did 2 base coats on my hood and sanded down to 2000grit (very smooth), but the color does look a bit off. Should I be sanding down the paint coat or should I leave it as it is, and instead apply my 6 or so clear coats and just sand that down.
FLIPbmw is offline   Reply With Quote
Old 08-23-2009, 04:35 PM   #2
Ceeker
better use a tack cloth before shooting the clear down to clean excess debris and dust from the surface. color will be a bit off. it's fresh paint!!! it's all in the prep. Then shoot the clear and after letting it dry polish the paint.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-23-2009, 04:38 PM   #3
FLIPbmw
but to sand the paint or not to sand?
Old 08-23-2009, 05:36 PM   #4
Ceeker
won't matter. it's flat paint therefore it won't change. you can't change the pigment by just sanding.
Old 10-05-2009, 09:06 AM   #5
njansenv
I'm pretty sure you don't want to be sanding metallic base-coat....
1998 328i "M-tech"
2001 TDI Golf. 1300km/tank commuter. Boring, slow, cheap.
1991 P-car: 964c4 Let the porcupine jokes commence.
Gone: '99 M3 vert, '98 M3 sedan, '91 E30, '89 E30, '87 E30, '91 Euro M5, '93 6-speed Corvette, STI v8 swapped '98 Impreza, '73 2002, 2004 325iT
njansenv is offline   Reply With Quote
