Welcome to!
Old 08-22-2009, 04:48 PM   #1
FS: 1988 e30 325i
Got a new car, so regrettably, it's time for the e30 to go.
For sale is my 1988 325i, either for parts or fixer upper.
-5 spd
- ~319,000km's
- Only Mobil 1 synthetic oil used (5w50)
- Black w/ dark tinted windows
- Interior is grey houndstooth sport seats in front, grey cloth in back with headrests and ski-bag armrest. Door panels are grey cloth / vinyl.
Was in a fender-bender 2 years ago. Not branded, the inner fender and rad support were bent in slightly, but were pulled back out. Hood does not fit 100%, but the car drives straight and alignment appears good. Has 1 new fender and 1 good condition used fender. Elipsoid light braket for DS was damaged, I still have the actual lights though. Replaced with Sealed Beams.
The floors are solid, except for 2 holes that I fixed in each of the front wheel wells. They were approx. 4 inches square right at the corner (typical rust spot) Cut out rust, por15, and fiberglass patched. Por15 applied to any surface rust on floorboards.
Will need work if you want to safety it. Right now off the top of my head, it would likely need:
- both rear e-brake cables are broken. I have the shoes still, hardware is likely gone. The holddown pins popped throught the backing plate.
- rear shock mounts
- either front strut bearings or the rack is going (has a hard spot when turning)
- one of the bolt holes in the RF wheel is losing the threading, hub would likely need to be replaced.
- small hole in the rear wheel well would need to be patched.
Would also need new rear glass. The defroster grid doesn't work.
U-joints may be on their way out. There is a slight rumble when you get on it in 2nd gear, but smooth other than that.
Lots of new parts in the last 2 years.
-Timing belt & waterpump done Oct 2007 at 311,000km,
- new wires, cap, rotor, plugs,
- o2 sensor, all rear bushings (subframe, trailing arm & swaybar).
- New driveshaft bearing
- intake gasket, tb gasket & intake hose
- coolant temp sensor
The rear door was also replaced with a good used door due to vandalism. However, the used door was apparently repainted with base/clear, and some of the clear is starting to peel.
Not e-tested, not safetied. Asking $800
Any questions, PM me.
e30jones is offline   Reply With Quote
Old 08-24-2009, 02:50 PM   #2
JDM soul
DYMO's Avatar
hmm interested... i'll get back to you
DYMO is offline   Reply With Quote
Old 08-24-2009, 08:22 PM   #3
bump, will consider parting if there is no interest in the car as a whole.
Car has 3.73LSD diff, K&N panel filter, cat-back muffler was replaced approx. 3 years ago, replaced all rear brake lines (rubber and steel).
100% Rust free sunroof panel removed from my parts car with only 90k km's (just installed on this car 2 weeks ago)
Also forgot to mention that the front suspension was done approx. 2 years ago as well.
- New control arms
- New m3 solid control arm bushings
- new tie rods (inner & outer)
I have put less than 9,000 km's on this car in the last 2 years. Would make a great winter car with a little bit of work.
I have the rear plastic bumper with rebar and like new shocks from the states that can be included with the car depending on final selling price (painted in black, have all bumper trim as well, never got around to installing)
Also have a rust free rad support with driver inner fender that I cut from a parts car that I can include if anyone feels up to welding it in.
Old 08-26-2009, 08:52 PM   #4
Will consider parting if there is enough interest in the big stuff.
Engine / trans
Diff 3.73LSD
full plastic bumper set with valance
front foglights
rust free sunroof panel
houndstooth sport seats (small holes in drivers seat bolsters)
the rest of the interior
grey 4 door carpet in good condition (removed last summer and cleaned)
good condition cluster
whatever else you might need
Old 08-28-2009, 10:38 PM   #5
how much for the plastic bumper and th front fenders. also what is the condition of the bumper and fenders. thanks.
clementine is offline   Reply With Quote
Old 08-31-2009, 11:48 PM   #6
sold pending payment...
Old 09-01-2009, 06:58 PM   #7
adam325i's Avatar
if it goes thru how much for the lsd diff? pm me please.
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 02-04-2010, 10:45 PM   #8
stiff for sale/
TPM is offline   Reply With Quote
Old 02-04-2010, 11:24 PM   #9
Originally Posted by TPM View Post
stiff for sale/
I don't think so considering that I have the passenger side fender from this car sitting in my shed
The rest of it has been scrapped.
Old 02-07-2010, 09:05 PM   #10
I believe digbutch bought this car....and is now parting it out
elroy is offline   Reply With Quote
Old 02-07-2010, 09:18 PM   #11
bigdutch's Avatar
yep.. that car is crushed..
bigdutch is offline   Reply With Quote
