Old 08-21-2009, 10:17 PM   #1
ChahalzBMR
1995 325i won't crank!?
ok...I did a lot of research on the EWS in the E36 but my car's production date is 12/94. I removed the glove box and found EWS in there. It use to crank just fine and then out of the blue it won't do anything.
All the lights come on when I turn the key but it won't crank. I don't even think my car has EWS because there was nothing behind the glove box.
Anyone ever have this problem or know what it might be?
91' CRX Turbo - Sold
94' 318i/M50 swap - Sold
95' 325i - Sold
97' Jetta - Sold
2006 Ford Freestyle - Sold
Looking for a E46 (00-04)
Steve
ChahalzBMR is offline   Reply With Quote
Old 08-22-2009, 03:59 PM   #2
ChahalzBMR
*edit* I removed the glove box and found no EWS in there.
95' 325i - Sold
97' Jetta - Sold
Steve
Old 08-23-2009, 01:07 PM   #3
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Hmm 95s should have EWS. You can also check the ECU the car has and that will also determine if it's non-EWS or EWS. If it's a red label 413 then it's non-EWS. If it's silver sticker I think that was with EWS. What about an alarm, do you have that?
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 08-23-2009, 03:21 PM   #4
ChahalzBMR
Its a red sticker. No alarm.
95' 325i - Sold
97' Jetta - Sold
Steve
Old 08-23-2009, 04:18 PM   #5
Dr. Flyview
"Mint"
Do the lights on the dash go dim when you try to start?
sold
Old 08-23-2009, 05:28 PM   #6
ChahalzBMR
Nope. I checked the starter and it has power coming to it. I tried hitting it and nothing works. I'm starting to think maybe its a fuse or something?
95' 325i - Sold
97' Jetta - Sold
Steve
Old 08-23-2009, 05:41 PM   #7
328i Cab
12/94 should NOT have ews. If you're really not sure, post a picture of the head (not the cut part that is cut to your car) of your key and I (or someone else) will confirm 1000%.
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
Old 08-23-2009, 05:46 PM   #8
ChahalzBMR
It doesn't have EWS. It has the red sticker and no EWS behind the glove box....so I'm sure there is no EWS in my car but I just don't understand why it will not start. Everything worked fine up until this problem. All the lights come on the dash and when I turn the key...nothing!
95' 325i - Sold
97' Jetta - Sold
Steve
Old 08-23-2009, 06:57 PM   #9
328i Cab
ignition switch maybe? the electrical part
Old 08-24-2009, 12:10 PM   #10
jeffrie
Addict
jeffrie's Avatar
Most likly the bendix on the starter is seized. Common for our cars and mine did the same.
Try push starting it, if all is fine and running after then it's most likly your culprit.
Old 08-24-2009, 03:13 PM   #11
ScotcH
Yup, push start is the key to diagnosing easily if it's the starter.
If it still doesn't start, then the next likely cause would be a weak battery. I know what you said ... light turn on etc, but if the ECU sense low power, it won't turn on the injectors and shit.
After that, it's anyone's guess: ignition, relays, wiring ...
Old 08-24-2009, 06:27 PM   #12
ChahalzBMR
thanks guys will try that if that doesn't work then off it goes to bimmersport
95' 325i - Sold
97' Jetta - Sold
Steve
Old 08-31-2009, 03:43 PM   #13
Dj_Aquarius
Equinox Lights and Sound
Dj_Aquarius's Avatar
Got the same problem this week, and try push start and it works so i drive around no problem but after parking and turn it off and try to start again nothing again.
so what you guys think the problem was?(ignition maybe)
Dj_Aquarius is offline   Reply With Quote
Old 09-04-2009, 07:39 PM   #14
ChahalzBMR
It's your starter
95' 325i - Sold
97' Jetta - Sold
Steve
Old 09-05-2009, 12:49 AM   #15
LondonWraith
LondonWraith's Avatar
def starter, bendix not engaging
LondonWraith is offline   Reply With Quote
