Old 08-17-2009, 02:45 PM   #1
gervs
gervs's Avatar
e36 steering rack swap
Has anyone here done this? How hard was it, i'm thinking of doing this as mine is on it's way out.
gervs is offline   Reply With Quote
Old 08-17-2009, 02:54 PM   #2
richie_s999
I think craz azn has the E36 m3 rack in his E30 send him a pm
Old 08-17-2009, 04:23 PM   #3
Aloush
how do you that its going out.. iam interested to know as my steering isnt the best currently.
Aloush is offline   Reply With Quote
Old 08-17-2009, 05:51 PM   #4
iignite
wat
iignite is offline   Reply With Quote
Old 08-17-2009, 06:06 PM   #5
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
Get this: 2.7 turns lock to lock
http://www.zionsvilleautosport.com/s...ode/E30SRC.htm
Grow up and move on.
Old 08-17-2009, 06:17 PM   #6
Nick_V
Nick_V's Avatar
Apparently the Z3 rack is the one you want. Not sure from which model though
Old 08-17-2009, 06:29 PM   #7
gervs
gervs's Avatar
I found this
http://www.r3vlimited.com/board/showthread.php?t=66247
I think i'm only going to go stock e36 (96+ M3 are the same as the regular e36, only 95 is 3.0 and z3 might be too hard to find)
I read contradicting comments on the z3 though, some say that it will have a wider turning radius than stock, others say it will be tighter than the others?
Old 08-17-2009, 06:40 PM   #8
gervs
gervs's Avatar
And found this for the non AirBag guys
http://www.akgmotorsport.com/e30products.html
Scroll down to swap accessories
Old 08-17-2009, 08:27 PM   #9
Aloush
Originally Posted by iignite View Post
wat
I for got to add the word "know"
How do you know that its going out ? as in what signs does it show or things that occur from steering going out..
Old 08-17-2009, 09:13 PM   #10
gervs
gervs's Avatar
1:You have puddles in your driveway, and you have to fill up on ATF fluid all the time.
2: You hear that signature power steering wined.
3: You have no power steering
Myself, I'm at 1, and 2 usually follows after fluid gets low. I just bought the E30, and was told the steering would 99% have to be replaced so I bought the car knowing it had to be replaced even though the seller did not mention anything about it. Clearly tried to hide the fact that he had to fill the fluid up now quite frequently himself as I can see (i have had the car 4 weeks now and it's starting to make the winding noise when cranking the wheel).
Old 08-17-2009, 11:32 PM   #11
Aloush
thanks for clearing it up.. what i did when i bought my car i took the car for a test drive.. saw where the owner parks his car and revisited the other day to see if there were any leaking spots on the ground..
Old 08-18-2009, 12:02 AM   #12
b-dawgGTA
a ton of info on doing this on rev
- 91 318is
b-dawgGTA is offline   Reply With Quote
Old 08-18-2009, 08:10 AM   #13
Berlin
i have a 97 Z3 rack for sale, pm me if interested
Berlin is offline   Reply With Quote
Old 08-18-2009, 09:35 AM   #14
supernaught
supernaught's Avatar
It might not be your rack(unless you're pinpointed the leak already).
Wipe everything down as best you can, then fill it up. Drive around a bit and see where its leaking from. It could be leaking from the base of the res, at the pump, or at the lines to the rack. If its coming out at either end of the rack, leaking through the ends of the boot, then it might be seals.
If you have tight steering, don't neglect the swivel joint in the column, it often gets clogged with dirt which leads to wear > firm steering and 'slop' in the wheel. Clean and grease this joint once in a while.
Old 08-18-2009, 10:51 AM   #15
Some guys on R3V confirmed that while the z3 rack is less turns overall lock to lock, at one turn it is still 50mm of travel, same as the E36 rack. The effective turning angle is the same until you hit lock, where the E36 turns a little farther.
