Old 08-12-2009, 11:59 AM   #1
sproule905
sproule905's Avatar
OIL RESET display.....
I recently changed my oil, and last time a buddy had the reset tool. its not major, but still annoying to see the yellow/red bars on my odometer.. I think there was a way to hook up a jumper wire to the engine connection to reset this. Does anyone have a picture or a website reference pointing this out?
thanks kids!
Old 08-12-2009, 02:02 PM   #2
doogee
doogee's Avatar
http://www.bmwe36blog.com/2007/02/24...service-light/
Dakar M3 Track Build Thread
Old 08-12-2009, 02:44 PM   #3
sproule905
sproule905's Avatar
FACK! the site is blocked by my work internet.. Can you post a pic with the terminals needed to do this?
thanks!
Old 08-12-2009, 05:33 PM   #4
LondonWraith
LondonWraith's Avatar
here is pic use ports 7 and 19
LondonWraith is offline   Reply With Quote
Old 08-12-2009, 05:49 PM   #5
Steve30
Techno Viking
Steve30's Avatar
i did it to my dad's 320 a few weeks ago and it worked like a charm!
E36 ///M3 S54
Old 08-12-2009, 05:56 PM   #6
LondonWraith
wicked colour Steve!! nice ride
Old 08-12-2009, 06:04 PM   #7
Steve30
Techno Viking
Steve30's Avatar
thanks
E36 ///M3 S54
Old 08-12-2009, 06:46 PM   #8
sproule905
sproule905's Avatar
thank you so much LondonWraith.. dam internet war lords blocking all the good shit!
thanks!!!!!
Old 08-13-2009, 03:26 PM   #9
sproule905
sproule905's Avatar
hey guys.... what's the procedure for doing this? turn on the car and apply the brakes or something? I've only ever done this the proper way with the reset tool.
thanks,
Old 08-13-2009, 04:03 PM   #10
Steve30
Techno Viking
Steve30's Avatar
OK, now you’re ready to reset the oil service light, so turn the ignition key to position II, but don’t start the car. Get out of the car and go to the data port. Always connect pin 7 first. Once you’ve inserted one end into pin 7, insert the other end into pin 19 and hold it there for 4 seconds. Then remove the paperclip. Check the dash and the oil inspection lights should be reset. The reset occurs upon removal of the clip.
E36 ///M3 S54
Old 08-13-2009, 04:17 PM   #11
sproule905
sproule905's Avatar
i will let you know how that works!
thanks A LOT!!! how's the crummy weather in T.O these days? I just moved to AB and its sunny blue skies!!! BUT the winters are another story!!!
Old 08-13-2009, 04:23 PM   #12
archins
Send a message via Skype™ to archins
Originally Posted by Steve30 View Post
OK, now youíre ready to reset the oil service light, so turn the ignition key to position II, but donít start the car. Get out of the car and go to the data port. Always connect pin 7 first. Once youíve inserted one end into pin 7, insert the other end into pin 19 and hold it there for 4 seconds. Then remove the paperclip. Check the dash and the oil inspection lights should be reset. The reset occurs upon removal of the clip.
On EUR version I have pin 7 to 1 and must hold ~ 15-20 sec
BMWMPOWER.LATVIA
archins is offline   Reply With Quote
Old 08-13-2009, 04:50 PM   #13
sproule905
sproule905's Avatar
MODS should sticky this... agree??
Old 08-14-2009, 05:44 PM   #14
sproule905
sproule905's Avatar
just an update - this worked beautifully!!
thank you!!!
Old 08-14-2009, 06:33 PM   #15
LondonWraith
glad it worked for you!
