Old 08-11-2009, 02:48 PM   #1
MPulse
MPulse's Avatar
Arrow Where to Buy
Trying to do my inner tie rod, and you need some bmw special tool. I did a little research and found out I can use w 32mm thin wrench. Problem is cant seem to find this anywhere. Anyone tackle this problem before?
MPulse is offline   Reply With Quote
Old 08-11-2009, 05:54 PM   #2
kenmar
I looked at this briefly when I did my tie rods and noticed you needed a special tool, so I only did the outer ends where most of the wear occurs (they weren't worn, but wanted to replace them since they were original). I didn't realize it's a 32mm thin wrench that you need ... sounds the same as the fan clutch wrench. I got my fan clutch wrench from Princess Auto for $10 (it's not really thin, but works great for the fan)
kenmar is online now   Reply With Quote
Old 08-11-2009, 05:55 PM   #3
kenmar
BTW, 32mm is approx. 1.25" which is easier to source
Old 08-11-2009, 06:01 PM   #4
Ceeker
I tried to find both. An old German company used to carry it in the brand name Hazet.
32mm thin wall. You can buy the one from Princess and just grind it down. Lots of guys do this. It's not so easy using it for the fan clutch as stated. You got to find the right place to slide it through to hook onto the nut. it's rather a tight fit for the M20 engine. works easily for the M42.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-11-2009, 06:28 PM   #5
Trekz
i just used a pipe wrench.
Trekz is offline   Reply With Quote
Old 08-11-2009, 06:32 PM   #6
Ceeker
yup that works excellent on tie rods seriously... good thinking.!!! especially if you can't turn the sleeve.
Old 08-12-2009, 11:20 AM   #7
98Dinan3
98Dinan3's Avatar
32mm headset wrench from a bicycle shop... very thin, and works well for the fan clutch too
Old 08-12-2009, 12:10 PM   #8
mech9T8
mech9T8's Avatar
That's what I used when I did mine.
Worked great.
mech9T8 is offline   Reply With Quote
Old 08-12-2009, 09:39 PM   #9
W2WDETAILING
where can i get tierods locally i need everything for both sides
Old 08-12-2009, 11:23 PM   #10
MPulse
MPulse's Avatar
Ok so I rented a tool from partsource that didnt work. Then I tried a pipe wrench, which made it so much easier. I got the parts from Precision Tuning Motorsports. OEM LEMFOERDER $78.40 for each side. Thats for the whole tie rod though inner and outer together. If you just need the outer end then I imagine it would be less
Old 08-13-2009, 08:23 AM   #11
RMPMOTORS
RMPMOTORS's Avatar
We sell OEM and aftermarket parts!
www.RMPMOTORS.com
www.Facebook.com/RMPMotors
Old 08-14-2009, 04:58 PM   #12
MPulse
MPulse's Avatar
Anybody know a good place to get an alignment done.
