Old 08-11-2009, 11:38 AM   #16
craigIS
A.K.A. crossfire291
craigIS's Avatar
good job for a DIY....how long did it take?
flickr
Old 08-11-2009, 11:41 AM   #17
moogles
moogles's Avatar
i'd say it took like a month... but then again, the actual hours i put in each day is like 2 or 3 hours... and not everyday... im pretty sure if you went hardcore with this, you can do it in like couple weeks...the most time consuming part is the waiting for hardening...
its just i have work at 5pm to 1am...
moogles is offline   Reply With Quote
Old 08-11-2009, 11:44 AM   #18
344i
344i's Avatar
Just replace all the parts, leave it as is for now. You fixed most of it.
344i is offline   Reply With Quote
Old 08-11-2009, 12:44 PM   #19
hockeyfan27
hockeyfan27's Avatar
How long did it take to set? You might need to use more hardener.
hockeyfan27 is offline   Reply With Quote
Old 08-11-2009, 02:46 PM   #20
simplycars
simplycars's Avatar
bondo should be ready to sand in 2 hours tops - thick coat.
simplycars is offline   Reply With Quote
Old 08-11-2009, 03:08 PM   #21
damameke
i think there is a thread in Detailng that outlined the steps and the sandpaper to use, 2000 then 1000 with alot of water..
Old 08-11-2009, 03:42 PM   #22
hockeyfan27
That's what I was thinking. Usually I'm running out of 'workable' time, not waiting for it to harden.
Old 08-11-2009, 04:23 PM   #23
moogles
moogles's Avatar
actually... i've worked on my bondo as soon as like 20mins... but that was just one time...
and i put a lot of coats of bondo... i sand it, and some of the sanded metal might show... so i bondo again... and just keep repeating untill its thick enough, and its to the shape of the body...
Old 08-11-2009, 07:37 PM   #24
Willycool
PISTOLERO !
Willycool's Avatar
Very nice job..... You saved yourself a lot of $$$$$$$
The best way to fix the rust in the long run, is to cut it out, conditional the metal and weld in new metal. This requires a lot of expensive equipment such as:
Air grinder, welder, sandblaster and paint gun.
Your repairs probally would have cost you 5 to 6 k in the body shop.
Cheers,
Willy
Willycool is offline   Reply With Quote
Old 08-12-2009, 01:32 AM   #25
moogles
moogles's Avatar
yea... im aware thats the proper way... but i dont have that much cash... meh... i think i did an okay job..
