08-11-2009, 02:48 PM
Car: 97 328i
Where to Buy
Trying to do my inner tie rod, and you need some bmw special tool. I did a little research and found out I can use w 32mm thin wrench. Problem is cant seem to find this anywhere. Anyone tackle this problem before?
08-11-2009, 05:54 PM
Car: 325i, 335xi
I looked at this briefly when I did my tie rods and noticed you needed a special tool, so I only did the outer ends where most of the wear occurs (they weren't worn, but wanted to replace them since they were original). I didn't realize it's a 32mm thin wrench that you need ... sounds the same as the fan clutch wrench. I got my fan clutch wrench from Princess Auto for $10 (it's not really thin, but works great for the fan)
08-11-2009, 05:55 PM
Car: 325i, 335xi
BTW, 32mm is approx. 1.25" which is easier to source
08-11-2009, 06:01 PM
Car: 325IS 87-325IC 89-IC
I tried to find both. An old German company used to carry it in the brand name Hazet.
32mm thin wall. You can buy the one from Princess and just grind it down. Lots of guys do this. It's not so easy using it for the fan clutch as stated. You got to find the right place to slide it through to hook onto the nut. it's rather a tight fit for the M20 engine. works easily for the M42.
08-11-2009, 06:28 PM
Car: Gettin One Soon
i just used a pipe wrench.
1995 E36 318is
Engine Mods: 94 M50 motor, Lightweight Flywheel, SACH clutch, UUC shifter, Electric Fan, Header and Full Exhaust, Magnaflow muffler, CAI, Racing Dynamics Chip
Exterior Mods: M3 spoiler ( Not installed yet), Projector Headlights, M3 mirrors.
Suspension Mods: Front Strut bar, Eibach spings, Billstein Struts.
Interior Mods: M3 buckets, Reverse Glow gauges, Momo steering wheel, M3 Shift Knob, M3 Headliner
08-11-2009, 06:32 PM
yup that works excellent on tie rods seriously... good thinking.!!! especially if you can't turn the sleeve.
08-12-2009, 11:20 AM
Car: E36 Dinan 332is
32mm headset wrench from a bicycle shop... very thin, and works well for the fan clutch too
08-12-2009, 12:10 PM
Car: 2001 530i Mtech
That's what I used when I did mine.
Worked great.
08-12-2009, 09:39 PM
Car: 90 325I,
where can i get tierods locally i need everything for both sides
08-12-2009, 11:23 PM
#10
Car: 97 328i
Ok so I rented a tool from partsource that didnt work. Then I tried a pipe wrench, which made it so much easier. I got the parts from Precision Tuning Motorsports. OEM LEMFOERDER $78.40 for each side. Thats for the whole tie rod though inner and outer together. If you just need the outer end then I imagine it would be less
08-13-2009, 08:23 AM
#11
Car: E90 Race Car
We sell OEM and aftermarket parts!
08-14-2009, 04:58 PM
#12
Car: 97 328i
Anybody know a good place to get an alignment done.
