Old 08-10-2009, 02:34 PM   #1
jasonlau8023
factory lean theory? i don't buy it
hi everyone,
i have a 97 bmw 328is with M pkg. i lowered them with HR OE SPORT springs(grey colour) few months ago, which lowered the car 1 inch front and .5 inch rear. However, the driver side(both front&rear) are 6mm higher than passenger side. i measured the height on gas stations level ground, so there can't be measurement errors.
I did tons of research on this, it seems a lot of ppl have this kind of problem. there is a theory called factory lean theory, which states that the driver side higher than passenger side is because it's designed to compensate drivers weight(150lb assumed). but i don't really buy it because there isn't any official evidence backing it up. non of this mentioned in bentley manual or other posts. most importantly, not every car has the same problem. Yesterday i read about a thread that mentioned some e46 common front spring installation mistakes. I suddenly realized that if my springs were installed incorrectly? so i took few pictures of the springs and hope someone can help me out....(the bottom pic is the front driver side)
even if the factory lean theory is true, is there any way to balance the height? i just don't want my car leans everytime when i look at it... i love my car....and i believe most of bimmer owner love their cars like i do.
feel free to contribute your thoughts.
sorry about my bad english, hope i explained my question clearly..
jasonlau8023 is offline   Reply With Quote
Old 08-10-2009, 03:01 PM   #2
blk325i
blk325i's Avatar
bro.. it's 6mm... stop tripping
blk325i is offline   Reply With Quote
Old 08-10-2009, 03:07 PM   #3
BigD
the misanthropist
BigD's Avatar
Look at it this way, if the cars came corner balanced from the factory like this, then there would be a specific spring for each corner. There isn't - there's a front and rear. The strut lengths are identical.
It could be that your spring is possibly not seated properly. The ends of the coils should be parked against the ridge in the perches. The ridge is visible in your first pic. There's one like that for the top perch as well.
Old 08-10-2009, 05:11 PM   #4
jasonlau8023
thanks for replying guys.. the annoying thing is that sometimes when somebody sitting at rear the rear right get rubbing fender... i really just want it to be even, not just because of looking but also the safety..
BigD, do you have pictures of spring installed/seated properly?
Old 08-10-2009, 06:00 PM   #5
BigD
the misanthropist
BigD's Avatar
Not of my own but this pic shows it decently. Notice how the coil ends at the bottom, butted up against a ridge/wall in the perch. If your spring coil is not right up against that little seat there, that side will sit higher.
Old 08-10-2009, 07:04 PM   #6
W2WDETAILING
correct and juging by that picture it doesent look like the spring is sitting in that ridge look how compressed that last ring is.
Old 08-10-2009, 08:06 PM   #7
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
Hmm my car also sits higher on the driver's side with no one inside. RMP certified the car and told me the factory height is like that...
1998 BMW 328is - summer
1993 BMW 525i - daily
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 08-11-2009, 02:00 AM   #8
doogee
doogee's Avatar
Almost all e36's are like this.
Dakar M3 Track Build Thread
Old 08-11-2009, 08:18 AM   #9
pawcio
pawcio's Avatar
to test out the factory lean theory go back to the level gas station with a friend that can use a measuring tape and see if the car is even when you sit in it. unless your over 150lbs cause then the driver's side might be 1-2mm lower than the passenger side.
__
Old 08-11-2009, 02:25 PM   #10
jasonlau8023
to pawcio, i did check....it's even when driver was in.
i just don't think this "factory lean" is necessary.... what if someone sitting in passenger side... then ppl may wonder "oh, your car leans to my side....what's going on?"
anyways, thanks guys. i'll take it to a sponsor to check....
Old 08-11-2009, 02:43 PM   #11
doogee
doogee's Avatar
BMW was thinking about weight distribution, not how it looks with all your buddies packed in it.
Old 08-11-2009, 02:52 PM   #12
pawcio
pawcio's Avatar
Originally Posted by jasonlau8023 View Post
what if someone sitting in passenger side... then ppl may wonder "oh, your car leans to my side....what's going on?" .
make them sit in the middle back seat. everything will be balanced then.
__
Old 08-11-2009, 03:01 PM   #13
jasonlau8023
which of them show the correct spring installation
some are e46s, i'm confused....or they are all correct but just show different angle?
Old 08-11-2009, 03:09 PM   #14
jasonlau8023
although sounds stupid, that's what i did when ppl sitting in the back....
especially with e36 coupe, person sitting in the back usually sitting in the passenger side because they got in the car from passenger door for convenience, which easily make the car lean more to passenger side.... always rub fender......damn!
i'll make sure that my mechanic didn't install my spring wrong. if it is 100% because of the factory lean theory, i'll live with that...
Old 08-11-2009, 03:56 PM   #15
craigIS
A.K.A. crossfire291
craigIS's Avatar
jason- an off topic question.....would yoou be able to PM me pics of your car....i happen to believe that this a car i saw driving around chatham before i moved. was a nice car back then, nice and clean.
flickr
