Old 08-06-2009, 11:20 PM   #1
noodles101
ΛΦΕ
noodles101's Avatar
air bag light
hi guys . wat would cause the air bag light to come on?
my car is 96 328i
it came on and wont go away after restarting the car several times...
Old 08-07-2009, 09:06 AM   #2
JazzM
it won't go away, you have to reset it with a airbag scan tool or at the dealer.
T.
T.
Old 08-07-2009, 09:41 PM   #3
kenmar
Mine came on after doing my engine swap and stayed on. The code said that it was a ZAE control unit failure, so I swapped in used unit from a '95 Ti (mine is a '94 325i). Now it goes out after 2 minutes and gives an error code 18 which apparently means internal control unit fault. I'm assuming that this code is caused by using a slightly different control unit with a different p/n. I've been searching for a used unit with an exact p/n match but haven't found one yet, so I might end up shelling out $560 to the stealer for a new ZAE control unit. What a PITA!
Old 08-08-2009, 06:30 PM   #4
328i Cab
PM me the ZAE unit number you need. I may have one from my 95 325i that is the same.
Currently: 2002 C5 Z06, 2009 335i, 2012 M796, 1976 XS650
PM me for your sidewinder (laser cut) key blank and cutting needs. Have OEM pre-ews keys and replacement shells. Can do (almost) all BMWs up to 2008!
328i Cab is offline   Reply With Quote
