Old 07-27-2009, 04:09 PM   #1
Sergsam
Master
Sergsam's Avatar
Cheat LAMP CONTROL MODULE
I have pretty annoying message that some of right tail light bulb burn.
In fact all of them works properly.
E39 September 2000.
I think that Lamp Control Module get problem.
How solve this problem ?
Sergsam is offline   Reply With Quote
Old 12-23-2009, 08:56 AM   #2
Sergsam
Master
Sergsam's Avatar
The problem growing
Unfortunately no response for my previous post.
But now I have more problems.
Sometimes my left or right LOW BEAM light does not work. Or work Good!
Bulbs are good, they did not get a power from Lamp Control Module.
I don’t know what to do: replace it – is not cheap part.
Must be sure that it is broken!
Reprogramming also not cheap work, especially in dealer shop.
Anybody has similar problem?
Please share your opinion.
Thanks.
Old 12-23-2009, 10:57 AM   #3
carjoe
carjoe's Avatar
Find a used LCM and get it reprogrammed? Out of curiosity, check the trunk harness. I had some weird issues that traced back to one broken wire.
Sometimes it's the simplest thing.
93 325is - sold!
2000 540ia- sold!
Old 12-23-2009, 01:45 PM   #4
Sergsam
Master
Sergsam's Avatar
Used LCM is good idea, but not easiest.This is one way. Thanks
Harness is not related to this problem 100%.
Old 12-23-2009, 02:35 PM   #5
nachos23
SweetXi
nachos23's Avatar
Check other posting.... you got 2 going here....
Old 12-23-2009, 04:20 PM   #6
Max_VQ
Max_VQ's Avatar
Maybe fix it yourself: http://tech.bentleypublishers.com/se...%20A%20E39.pdf
Also see: http://www.bimmerfest.com/forums/sho...d.php?t=368859
Old 12-23-2009, 05:01 PM   #7
Sergsam
Master
Sergsam's Avatar
Originally Posted by Max_VQ View Post
Thanks!
Unfortunately this is for old before 1999.
I am looking for 2001 (after September 2000)
Happy Christmas.
Old 12-24-2009, 12:00 AM   #8
Max_VQ
Max_VQ's Avatar
Originally Posted by Sergsam View Post
Thanks!
Happy Christmas.
Why do you think this fix only applies to 1999 and earlier?
I thought they all use the same chip...
Old 12-24-2009, 08:41 AM   #9
Sergsam
Master
Sergsam's Avatar
First of all no more heat sink!
Totally different chip and same changes in pin assign.
Old 12-24-2009, 02:45 PM   #10
Max_VQ
Max_VQ's Avatar
Too bad.
I guess you have 3 choices:
(1) Buy used and put up with mileage tamper dot
(2) Buy used and re-code??
(3) Buy new uncoded, and pay someone to code it
Old 12-25-2009, 09:54 AM   #11
Sergsam
Master
Sergsam's Avatar
Too bad.
What is this mean???
I think it is not necessary, if I use from same model.
The price absolutly not afordable especialy now (Christmas Holiday)
Merry Christmas !
Thanks for help.
Good Luck.
Old 01-04-2010, 09:21 PM   #12
roachboy
E39 September 2000.
When I first bought my 1997 E39 540i I had the same message even though all the lights were working. Pick up a decent quality replacement bulb or two and switch out the bulbs. Sometimes the LCM doesn't detect older/cheap bulbs for some reason.
Clem
roachboy is offline   Reply With Quote
Old 01-04-2010, 10:10 PM   #13
Sergsam
Master
Sergsam's Avatar
The problem SOLVED
The problem disapear itself.
HOPE FOREVER.
Thanks all for help.
Happy New Year!
