Old 07-25-2009, 12:58 PM   #1
mr.rhtuner
Cylinder 1 Misfire on E46....
Hey guys, my gf's car started to slightly 'wobble/shake' when its turned on yesterday. I bought a OBD2 scanner and tested the car and got the code:
P0301 - Cylinder 1 misfire detected.
Now, I'm guessing the cheapest option for this repair might be getting a new spark plug and testing it that way, but is there any way I can find out if the coil is bad or not?
Also, Cylinder 1, is that the closest one to the front of the engine...beside the water pump?
thank you
bart
mr.rhtuner is offline   Reply With Quote
Old 07-25-2009, 02:47 PM   #2
nyzryd3
Your right, sparks first and maybe the coils too.
nyzryd3 is offline   Reply With Quote
Old 07-27-2009, 04:19 PM   #3
Max_VQ
Max_VQ's Avatar
Move coil #1 to a different cylinder and see if the code changes...
Cylinder #1 is at the front of the engine by the water pump.
Old 08-29-2009, 01:21 PM   #4
mr.rhtuner
Thank you for the help.
I figured this out a few days after making the thread, I moved the coil to a different cylinder and the same thing was happening so I replaced the coil and the car drives and runs great!
