Welcome to!
Old 07-23-2009, 07:50 AM   #1
whay to do w/ back plates for disc shoes
mine r rusted out ? any info?
bimmer30 is offline   Reply With Quote
Old 07-23-2009, 08:08 AM   #2
most vauge question of the year......install new ones?
Old 07-23-2009, 08:41 AM   #3
supernaught's Avatar
how bad? you might be able to use short bolts with washers - if the hole for the pins has rusted oversize.
If your plates are nearly gone - call the dealer for new ones.
Old 07-23-2009, 08:54 AM   #4
or use a drum kit hardware to hold the shoes in the backplate, it all depends how bad your back plate is
dannyb is offline   Reply With Quote
Old 07-23-2009, 08:56 AM   #5
14 Years with the E30
InfiniteDice's Avatar
Get stainless ones made, and have them made so they come apart in 1/2. lol
Old 07-23-2009, 09:08 AM   #6
oversized washers to hold the pins in place and if it's really bad; cut them off. get new from dealer and snip down one edge and rap around the hub and tack weld. or you can do the long route and remove the whole assembly including the bearing to install them properly. :-)
Do we have that here? most vague question of the year? do we give awards for that? (Grin)
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-23-2009, 09:09 AM   #7
Replace them.
You'll need to remove the hub, which means you need to replace the wheel bearings. Also it is a good time to change your parking brake cables. and all hardware.
