Old 07-22-2009, 05:50 PM   #1
bimmer30
After installing ebrake shoes
what is the proper way to adjust hand brake when finish installing the shoes on a 1991 bmw 318i?
bimmer30 is offline   Reply With Quote
Old 07-22-2009, 06:16 PM   #2
BmW1819
send me a pm
Old 07-23-2009, 09:07 AM   #3
dannyb
you can adjust the shoes in the back by adjusting #7
or in the front by adjusting #11
dannyb is offline   Reply With Quote
Old 07-23-2009, 09:16 AM   #4
first you release the tension at the parking brake handle.
Then you adjust the shoes using #7 the adjuster. You allow for a slight amount of drag while turning the disc. Then you tighten the cable at the parking brake handle if needed. Test each side with the wheels off the ground, before finishing off.
Old 07-23-2009, 06:05 PM   #5
BmW1819
t dot got it bang on u can't just adjust one and not the other u gotta do both for it to lock up even
Old 07-26-2009, 09:36 PM   #6
bimmer30
thanks man the tip helped alot i fixed them ebrake shoes properly
Old 07-29-2009, 10:55 PM   #7
BmW1819
send me a pm if u need any other questions
