Old 07-31-2009, 11:10 PM   #16
El Gato Liso
El Gato Liso's Avatar
UPDATE: Thanks for the input all. I still have a feeling that this wont be as easy (but not exactly) as it sounds.
TMRW i will be renting the spring compressor...what i will do is install the springs in the front and leave the shocks. although i do have shocks for the front, they are already in struts...and it looks as if i will be having a fun time pulling them out.
but for the rear i guess i will just change the springs and shocks back there too. shouldn't be an issue as it appears!!!
Ill post pics of pre and post work!
R.I.P. E30
Old 07-31-2009, 11:57 PM   #17
5thseries
biggerthen3
Just put the whole strut in... its an easy job, your shocks are distroyed, put everything on now.
5thseries is offline   Reply With Quote
Old 08-02-2009, 02:20 AM   #18
El Gato Liso
UPDATE
did the back(springs and shocks)...and it was NOT easy...wtf. im bouncing up and down like a mother...lol oh well its nice and lowww
R.I.P. E30
Old 08-02-2009, 11:02 AM   #19
matty.dc
matty.dc's Avatar
ummm......what do you mean not easy?all you have to do is take off the two nuts up top, lift the car, take off the bottom bolt and you replace both spring and shock.
2013 Ford Edge - Daily Driver
Old 08-02-2009, 11:54 AM   #20
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
What made the back difficult for you?
Stanceiseverything.com
Old 08-02-2009, 12:07 PM   #21
Wait.. wut? Are you driving around with just the rear lowered?
And what shock / spring combo did you put on that makes it bounce?
Old 08-02-2009, 01:04 PM   #22
El Gato Liso
the shocks were not easy because the nut kept turning with the shock itself...the little flat edge to counter that was practically rounded out from before i guess. to solve that i just tightened a vice grip onto the shock and let it push up against the body of the car. bolts came free and it was easy at that point.
the right side was not that bad to get the spring out, although i still had to use a compressor on the back springs. i dropped the trailing arm all the way down (after taking out the links) and it was easy there. the driver side was a different story...i almost busted a brake like lowering the trailing arm...the exhaust had to be dropped! that was a little bit of a pain, but it was done. put it all back together and it has one stiff ass suspension, in the back only :p
now today im working on the front...and i just got the front spring out and literally 10 seconds it starts pouring...my luck. sun is back so im oging back to work!
over all me doing this for the first time is what made it difficult.
im using Boge shocks on supersport springs
R.I.P. E30
Old 08-02-2009, 01:08 PM   #23
Sounds about right for the first time doing it. Keep up the good work. Remember it's not a race. Take your time and be careful.
Old 08-02-2009, 01:09 PM   #24
SamE30e
SamE30e's Avatar
Scott and I had fun with the strut insert nuts...
24" pipe wrench, witches piss, propane torch and weight of a parts car ftw.
85 325 - Turbo M52B28.
Old 08-02-2009, 02:05 PM   #25
(Once, I used a 24" pipe wrench with a 6' (!!) pipe around the handle in a vice, attached to a steel table. I had to have my brother sit on the table while I yanked on it.)
Old 08-02-2009, 03:28 PM   #26
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Heh I drove around with the back dropped for about 4 days.
Old 08-02-2009, 07:59 PM   #27
El Gato Liso
alright.
the back is lowered with new shocks.
the front passenger is lowered with new shock. the front driver side is still all stock. i am too tired today to even move onto the other. it will be done tomorrow! (through trial and error it should take about 2 hours or so!!!)
stiff suspension blows lol
R.I.P. E30
Old 08-03-2009, 08:05 AM   #28
dannyb
anyone know where i can get the struts insert nuts for bilsteins?
dannyb is offline   Reply With Quote
Old 08-03-2009, 08:50 PM   #29
El Gato Liso
done and done.
it was a slow process, but now i've learned all through trial and error. i keep scraping the road time for a skid plate lol.
pics will come in time!!!
thanks for all the input everyone
R.I.P. E30
Old 08-04-2009, 08:37 AM   #30
BMW BMXer
Wants a 350 Blazer.
BMW BMXer's Avatar
Glad to hear it all got done man!
