Old 07-21-2009, 05:33 PM   #1
Rockblock
Rockblock's Avatar
Who runs LEDs as replacement to low beam DRL?
Folks,
I'm debating between going to an indy shop to have my DRL turned off, or replacing the stock H7/55W with LED bulbs.
I've heard lots of people running LED bulbs (3,9,15,18,24 or 32 led) as an alternative to their stock DRL. The LEDs cost about the same amount (or less) you'd have to pay an indy shop to turn the DRL off and you can get LEDs in various color tones: 6000K (xenon white), 7000K (neon white), 8000K (bluish), 9000K (purple). A quick search on eBay provides tons of options.
So, I'd like to know if there's anyone out there running LEDs instead of the stock H7/55W bulbs - what brand do you use, what's your experience with them, and how do they look.
Cheers!
_________________________________________________
The more expensive the car, the cheaper the spare parts should be !
Rockblock is offline   Reply With Quote
Old 07-21-2009, 06:32 PM   #2
Blades
Your opinion is to long
Blades's Avatar
never seen them used .. your talking about the bulb not the angel eyes correct?
do you have pics of them in use?
-=[ BL/\DES ]=-
Old 07-21-2009, 08:03 PM   #3
Rockblock
Rockblock's Avatar
Yes, bulb replacement...here's a link to a LED bulb. You can actually get them from 1-32 led. I think you also need a resistor to ensure the error light stays off...
Here's a pic I found (can't remember where) of someone using a 1 led bulb (the small pupil in the middle)
Old 07-21-2009, 10:21 PM   #4
Steve@ASPTuning
Heh.... I drive out of city A LOT so LED high beams definitely won't be safe for me...
Steve
ASPTuning
Steve@ASPTuning is offline   Reply With Quote
