07-20-2009, 05:47 PM
#1
E90 n00b
Car: E90 323i
Error Loading OS
Installed a brand new WD1600AAKS (Western Digital Cavier Blue SATAII 160GB 16MB Cache). I cloned the disk from a 40GB Maxtor IDE drive.
When I go to load windows it just just shows the same error message over and over. So I thought maybe I can't just image the drive straight, so what I did was try a fresh install. At about 90% of copying windows xp files (the initial process after a format before it reboots and installs xp), it just crashes and says it cannot continue.
I tried changing from DMA to Large still no luck.
Bios is up to date.
Whats even weirder is I can image the Maxtor 40GB drive to a 160GB WD1600AAJS (Western Digital Cavier Blue SATA 8MB Cache) and that works.
Any idea?
I read that I need to "write 0's" to the drive first to put a proper MBR on there but I just cant find a way to do it with WD Data LifeGuard.
07-20-2009, 07:20 PM
#2
Car: .
windows. the problem.
07-20-2009, 08:08 PM
#3
Wants a 350 Blazer.
Car: 1985 325e
07-20-2009, 10:44 PM
#4
Car: E34 M5
If it's working on the 40GB disk and 160GB SATA disk then I'm guessing you have a bad 160GB SATAII disk. It happens, try exchanging it.
07-20-2009, 11:01 PM
#5
Car: .
Originally Posted by BMW BMXer
  back at you
07-20-2009, 11:47 PM
#6
is a pimp
Car: E46, E36
Could it be possibly a bad drive out of factory?
have you ran the checkup?
07-21-2009, 12:25 AM
#7
Car: .
on a serious note, most likely a bad drive. Never had a issue cloning before, however had issues with western digitals. One was reporting as a 80 gb while it was infact a 200gb. It also didn t work or allow anything to be installed to it, had to be exchanged.
07-21-2009, 12:28 AM
#8
is a pimp
Car: E46, E36
Usually when you try to install windows... it will say "this drive may fail soon, we suggest you install on another drive"
07-21-2009, 08:37 AM
#9
Car: 2002 BMW 330i
I'd also suggest that this drive is faulty.
2006 Range Rover Sport, 2007 Toyota Yaris, 1996 Chevrolet Cavalier, 2002 BMW 330i - SOLD
For Professional Mobile Applications and Internet Marketing, click here.
07-21-2009, 09:51 AM
#10
Your opinion is to long
Car: 330XI
Ever since XP came out Microsoft decided that it would be a good idea to limit the amount of hardware changes you can do on your pc before the OS craps out (piracy prevention for microsoft). I'm sure the hard drive works .. but it could be the image as well .. what software did you use to make an image? Does the software give you the option of changing the SID before booting up?
-=[ BL/\DES ]=-
07-21-2009, 12:32 PM
#12
Car: 330XI
Originally Posted by Jim .E.
Acronis True Image Enterprise edition
Good Ol' Norton Ghost 2003
and also a fresh install
but none of that works. Just going to exchange it for a 8MB Cache WD1600AAJS.
Acronis ..good choice
bummer that it didnt work out for you. Better check your hardware specs and what your mobo can handle.
-=[ BL/\DES ]=-
