Go Back   maXbimmer Forums > Specific Regional Areas > Windsor, Ontario
Old 07-07-2009, 03:48 PM   #1
craigIS
A.K.A. crossfire291
craigIS's Avatar
Exclamation rear diff problem...
well i just bought my car last wek, and i just started haveing trouble with the rear differential. i hear this knocking sound sometimes when i shift, and sometimes in gear randomly. when im driving donw the road in gear, the diff will knock, and throw the car to the the side.
i looked at the car before i bought it, and didnt notice anything such as leaking diff fluid. so i looked under the car yesterday when this started to happen, and where i parked the car, there is a small puddle of diff fluid on the ground.
is there any quick fix for this? or, am i effed, and need a new diff.
also if i wanted to put some fluid into the diff, how would i do that?
thanks in advance.
flickr
Old 07-07-2009, 04:30 PM   #2
BigD
the misanthropist
BigD's Avatar
Something is either badly broken (beyond fluid changes) or you have a flat tire (kidding).
Jack up the rear with the wheels off the ground and rotate them. See/feel what happens, and report your findings.
Old 07-07-2009, 06:04 PM   #3
craigIS
A.K.A. crossfire291
craigIS's Avatar
actually, i dont think its the diff any more.....i believe it to be the CV axel....the leak is right on the joint, and further inspecting under the car, the leak is on the the same side as where the noise is coming from.
flickr
Old 07-07-2009, 09:12 PM   #4
craigIS
A.K.A. crossfire291
craigIS's Avatar
well, my car just stopped driving, it just sounds like loud ass grinding kinda. it does it in every gear, just does not move.
actually i can put it into reverse it it will reverse half ass.
im still wondering what the issue could be, CV axel, or the diff.....
flickr
Old 07-07-2009, 10:08 PM   #5
BigD
the misanthropist
BigD's Avatar
It's a blown halfshaft.
Old 07-07-2009, 10:45 PM   #6
+1 on that, from the description of the problem, all signs point to that!
Old 07-07-2009, 10:49 PM   #7
craigIS
A.K.A. crossfire291
craigIS's Avatar
is there any way i can tell whether its the halfshaft? will it not move?
flickr
Old 07-07-2009, 11:33 PM   #8
^^^http://www.maxbimmer.com/forums/showthread.php?t=122384
Old 07-08-2009, 10:29 AM   #9
Aloush
Your Guibo is probably gone.
Aloush is offline   Reply With Quote
