Old 07-07-2009, 12:25 PM   #1
craigIS
A.K.A. crossfire291
craigIS's Avatar
Exclamation rear diff problem...
well i just bought my car last wek, and i just started haveing trouble with the rear differential. i hear this knocking sound sometimes when i shift, and sometimes in gear randomly. when im driving donw the road in gear, the diff will knock, and throw the car to the the side.
i looked at the car before i bought it, and didnt notice anything such as leaking diff fluid. so i looked under the car yesterday when this started to happen, and where i parked the car, there is a small puddle of diff fluid on the ground.
is there any quick fix for this? or, am i effed, and need a new diff.
also if i wanted to put some fluid into the diff, how would i do that?
thanks in advance.
flickr
Old 07-07-2009, 06:15 PM   #2
hypno_nls1
hypno_nls1's Avatar
Hopefully its not the same problem that I was having, when my diff began knocking like that during gear changes and sometimes not during gear changes like on hills and what not, it was my rear subframe that had gone through.
Fear Nothing. Risk Everything.
This is not your everyday, ordinary ****ing beamer!!
hypno_nls1 is offline   Reply With Quote
Old 07-07-2009, 06:58 PM   #3
Ceeker
Jack the rear up on jack stands and remove the backing plate to the diff make sure you block the front wheels. Put the car in in neutral and slowly spin the wheels and looks for anything unusual or loose. Start the car and put it in first and slowly let the clutch out and have someone watch or listen while you accelerate a "little" you don't want to throw the car off the stands if by chance you're too jerky.
Or you can take it to a shop with a hoist and have the throw it in the air to check out.
good luck.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 07-07-2009, 09:11 PM   #4
craigIS
A.K.A. crossfire291
craigIS's Avatar
well, my car just stopped driving, it just sounds like loud ass grinding kinda. it does it in every gear, just does not move.
actually i can put it into reverse it it will reverse half ass.
im still wondering what the issue could be, CV axel, or the diff.....
flickr
Old 07-07-2009, 09:43 PM   #5
Its very easy to tell; jack the car up, remove wheels (for more visibility), start the car and put in gear. Now look at what spins; if driveshaft spins, but none of the axles move, then problem is in the diff. If output flanges move (and possibly the axle itself) but wheels dont, it can be CV (or stripped hub).
In any case, its not a big deal, few hours of work in the worst case...I also have all the parts you can need!
Old 07-07-2009, 09:47 PM   #6
[QUOTE=crossfire291;1322153]well i just bought my car last wek, and i just started haveing trouble with the rear differential. i hear this knocking sound sometimes when i shift, and sometimes in gear randomly. when im driving donw the road in gear, the diff will knock, and throw the car to the the side.
The diff can NOT throw the car to the side! In no way is it supposed to move at all...You might have problems with rusty subframe mounts etc...
Old 07-08-2009, 05:49 PM   #7
Wannabe
Northwood.
Wannabe's Avatar
a bad ujoint will also cause clunking when shifting..
Current - 2011 Jeep Grand Cherokee Laredo
2010 Jeep Patriot North All-season
2009 Jeep Wrangler Unlimited Sahara
2002 Dodge Durango SXT
1985 BMW 325e
1998 Pontiac Grand Prix GTP
1995 Nissan Altima SE
1994 Mazda MX-6 RS
1984 Buick Riviera
Wannabe is offline   Reply With Quote
Old 07-08-2009, 07:31 PM   #8
hypno_nls1
hypno_nls1's Avatar
this is beginning to sound more and more like my problem, once the knocking got worst it then led to loud grinding which was the driveshaft jsut rubbing on the subframe of the car, but my car still moved however, but very very slowly
Old 07-08-2009, 09:09 PM   #9
craigIS
A.K.A. crossfire291
craigIS's Avatar
i havent had time to get the car up on jacks today, so that will be the plan tomorrow. from what i can see, every thin that is visible looks fine, there is not obvious damage, and the rust under the car is just surface, and not rotting. ill update tomorrow.
flickr
Old 07-09-2009, 07:37 PM   #10
craigIS
A.K.A. crossfire291
craigIS's Avatar
well, i got the car on jacks today. the CV Axle on the driver side is kinda wiggles around you pull on it, while the passenger side does not.
the drive shaft turns while the car is in gear. there is no grinding sound at all while the car is in the air. also both tires also turn while on jacks, but the driver side, you can stop buy gabbing and holding the wheel. the passenger side does not do that.
basically im thinking the CV rod is pooched, or its the diff.....what do you think?
flickr
Old 07-09-2009, 10:45 PM   #11
I would say the hub is stripped, the axle should be tight in the hub...thats why its wiggling and you can stop the wheel...When the wheel is stopped, look at the alxe, does it still spin...or does it also stop?
Old 07-09-2009, 11:11 PM   #12
BigD
the misanthropist
BigD's Avatar
The CV joints and the axle itself would snap before the hub would strip. It's just a blown CV joint, no need to continue agonizing over it. Buy a new or find a used halfshaft and get on it (or go ask your favorite mechanic for a quote).
Old 07-09-2009, 11:48 PM   #13
I have seen it happen twice...in both cases the axle would spin inside the hub. One of the times the axle nut was loose and the splines stripped...
Old 07-10-2009, 05:00 AM   #14
magnus
magnus's Avatar
Bearing? Or the diff its self has gone BYE BYE!
http://pics.livejournal.com/blblblblx/pic/000r554e.gif
"Lo there do I see my father.
Lo there do I see my mother.
Lo there do I see my brothers and my sisters.
Lo there do I see the line of my people back to the beginning.
Lo they do call to me
they bid me take my place among them in the Halls of Valhalla,
where the brave may live forever"
magnus is offline   Reply With Quote
Old 07-10-2009, 07:59 AM   #15
BigD
the misanthropist
BigD's Avatar
Wow, well I'll take your word for it but that's crazy. Did the axle pull out partially?
