Old 07-05-2009, 11:24 PM   #1
matty.dc
matty.dc's Avatar
Check oil light came on
My engine oil light came on, on the overhead cluster. I got out immediately to check the level of the oil and it was fine. The oil light in the gauge cluster remained off the entire time. Any ideas?
Matt
2013 Ford Edge - Daily Driver
Old 07-06-2009, 12:43 AM   #2
E30Rider
E30Rider's Avatar
Send a message via MSN to E30Rider
maybe your oil pressure switch is gone, i had the same problem and i'ved replaced mine last week..
E30Rider is offline   Reply With Quote
Old 07-06-2009, 01:47 PM   #3
FuryriderX
cra.iX.y
FuryriderX's Avatar
overhead check panel light is supposed to come on when the oil level is 1L low.
could just be a malfunctioning level sender, it happens every so often.
Old 07-10-2009, 07:54 PM   #4
adam325i
adam325i's Avatar
mine does that when ever i go over a certian speed limit or slamm on the breaks and the coolant one goes out too. but the fluids are all fine.
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 07-11-2009, 04:24 AM   #5
juzer
7000 RPM
juzer's Avatar
Check oil again when cold, if little below line add 1/2L and see if light goes out.
juzer is offline   Reply With Quote
Old 07-11-2009, 02:22 PM   #6
That light can be sensitive; it's like a 'first warning' light. Agree with juzer, check when cold, top up.
Old 07-23-2009, 01:49 PM   #7
Starsky
I had that happen in my ix. Turned out to be where the sensor plugs into the harness, it had come unplugged. I plugged it back in and all is fine again. Look for a wire harness coming out of the oil pan.
89 325ix - stock
97 Miata - turboed, intercooled, and megasquirted
Starsky is offline   Reply With Quote
