Old 06-21-2009, 04:57 PM   #1
frankzen
frankzen's Avatar
New problem
My '95 318 has developed something new...starting at about 60 kmh I can hear a slight humming..and feel a slight vibration in the body of the car..not a shaking just a low level vibration. What do ya think wheel bearings?.
Just one more problem to add to the long list!!!
--'95 318i--
frankzen is offline   Reply With Quote
Old 06-21-2009, 06:07 PM   #2
5thseries
biggerthen3
Balll joinntts!
5thseries is offline   Reply With Quote
Old 06-21-2009, 06:19 PM   #3
Wheel bearings- could be. Steer hard from side to side and see if the sound becomes louder as you do this. Or when exiting a ramp depending on which side the bearing is gone the sound will come from there. Ball joints? possible too.
2 IX's -sold and parts
2 325i 4 dr - sold
1 87 325is red - parts
1 89 325i vert grey - parts
Old 06-21-2009, 07:08 PM   #4
frankzen
frankzen's Avatar
OK two votes for ball joints..one for bearings
I do notice a change in the sound on right hand turns on exit ramps but I don't know whether I'm imagining it.
Any way to check and be sure before I let a "mechanic" take a look/listen to it ?
--'95 318i--
Old 06-21-2009, 07:34 PM   #5
5thseries
biggerthen3
If it was the bearings... you will HEAR it.. its like rollerblading on epic pavement sound
If its a humming and slight vibration.. most likely the ball joints.
Go the mechanic and get a front end inspection
Old 06-21-2009, 07:45 PM   #6
frankzen
frankzen's Avatar
OK thanks for the input. I do know the right lower control arm is shot..I can hear that noise on bumps at low speed. Gawd I hope its not bearings...from what I've heard that is big bucks! And I already have enough to spend on this car.
--'95 318i--
Old 06-21-2009, 09:53 PM   #7
5thseries
biggerthen3
Is it like a *clunk clunk* sound when you go over bumps??
Old 06-22-2009, 08:35 AM   #8
frankzen
frankzen's Avatar
Well...it's a *clunking* sound...from the right front...but I don't **think* it's connected to the other problem (the humming sound). I've already been told by a mechanic the right control arm in front is shot. The humming sound starts at about 60 KMH even on smooth roads..the vibration I feel is like touching a running electric motor.
--'95 318i--
Old 06-22-2009, 09:35 AM   #9
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
Send a message via MSN to INFAMOU$
wheel bearing is the humm.. the clunk is the control arm bushing
INFAMOU$ is offline   Reply With Quote
Old 06-22-2009, 10:23 AM   #10
5thseries
biggerthen3
What about the links??
Old 06-22-2009, 02:10 PM   #11
frankzen
frankzen's Avatar
wheel bearing is the hum.. the clunk is the control arm bushing
That's what I was afraid of. Judging by the variation in noise on right hand tuns, it seems to be the left side. The hum is not very loud...but it's there.
--'95 318i--
Old 06-22-2009, 09:44 PM   #12
INFAMOU$
INFAMOU$'s Avatar
Yea.. the opposite side from the way you turn will be the side the bearing is faulty.. because when you turn the other way it takes some of the load off of it making the HUMM quieter.. You'll be able to drive for a bit with it but should replace it.. pick up a used spindle and just swap that as it may be cheaper and easier for you with hand tools! The control arm bushings are pretty easy to replace too and very affordable.. you might as well get ///M ones as they are slightly offset for "better performance"
Old 06-22-2009, 10:17 PM   #13
frankzen
frankzen's Avatar
Thanks for that info - sounds like the spindle swap would be easier. Re the control arm..two garages have suggested they replace the whole arm? Why , if the bushings are cheap and easily replaced ?
--'95 318i--
Old 06-22-2009, 11:56 PM   #14
INFAMOU$
INFAMOU$'s Avatar
That ridiculous.. if your UPPER balljoints were gone then they may suggest that as they are not replaceable and part of the CA. The lower balljoints are replaceable and can be pressed in.. The control arm bushings themselves are a breeze tho! 2 bolts and you can pull them off the CA and use a vice to press new ones in.. then you use dish soap to squeeze the arm through the rubber bushing and bolt it back on.. should take you no time to do them!
Old 06-23-2009, 08:47 AM   #15
frankzen
frankzen's Avatar
Good. Thanks for that. What's the best way for them to check the upper ball joints?
So many questions!!
--'95 318i--
Tags
318, humming sound, vibration
