Old 07-03-2009, 09:43 PM   #1
george_328i
Gear Box Chatter
Hey Guys,
My Buddy has an m3 conversion with a light weight flywheel and prformance clutch. Everytme he pulls up all you can hear is a chattering noise from the gearbox area. The sound seems to go away when he pushes the clutch pedal to the floor. Do you guys think it could be because of the light weight flywheel?
george_328i is offline   Reply With Quote
Old 07-04-2009, 02:11 PM   #2
Trouble65
Originally Posted by george_328i View Post
Hey Guys,
That's what I would think. My 540i/6 has carbon fibre clutch and does the same if I'm to easy on it.
Old 07-04-2009, 02:42 PM   #3
spoony_prelude
Eurowerke
spoony_prelude's Avatar
Same with mine. When the clutch pedal is pressed down, the noise stops. When I release the pedal the noise starts. Although not sure if anyone else has noticed but theres a difference in how loud it gets by how much amperage im using for example. If I have my lights on, its pretty loud, meanwhile I turn my lights off and the noise goes down quite a bit!
2011 M3 coupe/moonstone/fox red
Old 07-04-2009, 07:14 PM   #4
It's the Flywheel.
http://www.uucmotorwerks.com/flywheel/gear_rattle.htm
Old 07-04-2009, 11:19 PM   #5
TMA
TMA's Avatar
The car used to be mine... I had Bimmersport install a lightweight flywheel and brand new OEM M3 clutch kit (bearing, pressure plate, and disc)... So theres nothing wrong with any of the parts I know that for sure. Its called "gear rattle" because of the flywheel being so light there is less mass slowing down all the gears that are meshing with each other inside the transmission. That is why when you press the clutch down those gears stop spinning and make no noise. The lighter the flywheel, the louder the gear rattle gets.
There is a solution to quiet down the gear rattle. You have to change the tranny fluid to something thicker I believe, I can't remember exactly what I was recommended to use, but I'm sure someone on here would know. It doesn't completely eliminate the rattle, but it reduces it by more than half.
-Dave
TMA is offline   Reply With Quote
Old 07-05-2009, 11:01 PM   #6
BmW1819
input shaft or flywheel
Old 07-06-2009, 03:12 PM   #7
dejan_da_dude
E36-err
dejan_da_dude's Avatar
Hey dave
The car is running great, pulls harder then ever and im getting hated on by the 240 hahah.
Yea I asked George to put up the thread on the gear chatter, Just to hear some opinions and like u said, maybe changing the tranny fluid to something thicker would help.
dejan_da_dude is offline   Reply With Quote
Old 07-06-2009, 03:20 PM   #8
Fel
Not Banned
Fel's Avatar
I had this happen in my e34 525.... stock clutch and flywheel.
I was told that it was the flywheel rattling... mine had a dual mass flywheel, and it was mentioned that the two pieces over time had come a little bit loose and were making the noise. It doesn't affect drivability, but it does get annoying. (And that's only what I was told, I don't know if this is fact or not).
Old 07-07-2009, 01:18 PM   #9
dejan_da_dude
E36-err
hmm, that would suck if it were true, but then again, my car sounds like a deisel when I idol hahaha
Old 07-08-2009, 12:25 PM   #10
TMA
TMA's Avatar
Dejan.... thats not the case with your car. That flywheel is brand new. Its just simply gear rattle caused by the lighweight flywheel. Its annoying I know, but its worth it just to have the ability to rev the engine so quickly for rev-matching.
-Dave
Old 07-08-2009, 03:56 PM   #11
dejan_da_dude
E36-err
Yea, I love that. it scares people how fast it is.
Hope ur having a good one Dave.
Old 07-14-2009, 12:49 PM   #12
black bnr32
black bnr32's Avatar
redline MTF is a common 'thicker' tranny fluid to use to hel with gear rattle. no experience myself, but its well documented on bimmerforums.
black bnr32 is offline   Reply With Quote
Old 07-14-2009, 01:42 PM   #13
dejan_da_dude
E36-err
Nice, I will defenitly give it a look into. Thank you for help guys
Old 07-16-2009, 12:23 PM   #14
JUS_CRZN
My other car's a jet.
JUS_CRZN's Avatar
Its called race car noises, enjoy it!
I have UUC stage 2 and it rattels.
JUS_CRZN
JUS_CRZN is offline   Reply With Quote
Old 07-16-2009, 12:45 PM   #15
parm
Scarboro Mazda S&L
parm's Avatar
Gear rattle, Shut the car off with the clutch engaged and listen, then do the same thing this time without engaging the clutch.
