Old 06-28-2009, 02:52 PM   #1
FuryriderX
cra.iX.y
FuryriderX's Avatar
FS: 17x7 ET42 4x100/4x108 rims with rubber
Not quite sure of the brand of these wheels. Due to the offset they will only fit on an e30 iX or a volkswagen, unless you use 15-20mm spacers (which i do not have).
You will also need cone seat tuner lugs (which are not included)
The clearcoat on the lips is damaged, due to the previous owner using them in the winter (salt). I would highly recommend refinishing (or at least resanding/polishing) the lips. In the picture you can see the blemishes (it doesnt look quite that bad in person, but it shows clearly) and the only spot of curb rash on the set (9:00 on the wheel, about 2 1/2" long)
Comes with 85% tread 215/45/17 off brand summer performance tires, very slightly camber worn on the rear. See picture for tread depth.
Asking $500.
Tires are currently mounted on rims, but off the car. PM is key.
Old 07-01-2009, 07:55 AM   #2
FuryriderX
cra.iX.y
FuryriderX's Avatar
bizzump.
they're actually et40, basically the same.
EDIT: more pics added.
