Old 06-21-2009, 03:13 AM   #1
llbronzell
Suspension problem....
So I bought my BMW last summer and I've noticed since owning it when I hit a pothole or a deep manhole my car slightly rocks side-to-side. Well this summer I've put on new rims and tires and the rocking is getting progressively worse to the point where I feel I may fishtail and lose control of my car. By the way my suspension is stock new rims are 17x8 38 offset, alignment was done after the rims were installed.
Has anybody had this problem? and how did you fix it? Any thoughts or suggestions is also welcome
llbronzell is offline   Reply With Quote
Old 06-22-2009, 12:04 AM   #2
Pongs318
You need shocks I have a set if you want for cheap,I can also install let me know
Pongs318 is offline   Reply With Quote
Old 06-22-2009, 04:17 AM   #3
INFAMOU$
Automotive Puppeteer
INFAMOU$'s Avatar
Your rear trailing arm bushings are worn!! Buy a new set ($15ea) from part source.. put them in the freezer overnight.. next day you'll have to drill/pry the old ones out and hammer in the new ones.. I did both of mine in 1 hr..
Old 06-24-2009, 04:17 PM   #4
llbronzell
Thanks INFAMOU$
You're exactly right, took my car over to Bimmex for an inspection and that's exactly what they told me (amongst other things they "recommend" to replace). Will take your advice and head over to part source.
Old 06-24-2009, 09:55 PM   #5
INFAMOU$
INFAMOU$'s Avatar
Glad to help!
Cheers
