Old 06-18-2009, 02:51 PM   #1
BMWnoob
grrrr etest failed... some help where to start
So I had to get some ownership transfering done and the MTO says i have to redo etest..i did as told and it failed in one category
Curb Idle HC PPM 200 / 718 FAILED
40KM Limit / Reading Results
HC PPM 60 / 13 Passed
CO% 0.33 / 0.18 Passed
NO 0675 /19 Passed
Curb Idle Limit/ Reading Results
HC PPM 200/ 718 FAILED
CO% 1 /0.07 Passed
Anyone help with where to start?
searching tells me misfire, dirty injectors and unburnt gas
I sometimes get the feeling that the car smells a lot inside of gas. (could be just me reving too much learning to drive it but my dad mentioned the car smells quite a bit as well) Possible vaccum leak of some sort?
Any help for the clueless?
BMWnoob is offline   Reply With Quote
Old 06-18-2009, 02:55 PM   #2
Duct_Taper
Sticky
Duct_Taper's Avatar
High HC at idle means it's running rich.
Does it idle properly? Any smoke?
I'd check the IAC for a start.
Duct_Taper is offline   Reply With Quote
Old 06-18-2009, 03:12 PM   #3
Max_VQ
Max_VQ's Avatar
I agree that it seems to be running rich at idle.
How old are the O2 sensors and spark plugs?
Old 06-18-2009, 03:27 PM   #4
BigD
the misanthropist
BigD's Avatar
If a car you just bought fails emissions, replace the spark plugs and O2 sensor before guessing. Buy an O2 from a 5.0 Mustang from Crappy Tire for 55 bucks (exact same Bosch sensor), crimp on the connector from your old one. If it still fails at that time, then start thinking.
Old 06-18-2009, 03:43 PM   #5
BMWnoob
i don't notice any smoke on idle.. and it seems to be running nice... it pretty much starts right up if i stall or first start of the day..
what is the IAC? as everyone knows already i don't know anything about anything...when it comes to cars
Old 06-18-2009, 04:20 PM   #6
BigD
the misanthropist
BigD's Avatar
If it starts smoking then it's time to call a car priest. Change the spark plugs and O2 sensor.
Old 06-18-2009, 05:12 PM   #7
SamE30e
SamE30e's Avatar
Do the plugs, wires, o2 and check for vacuum leaks.
85 325 - Turbo M52B28.
Old 06-18-2009, 05:27 PM   #8
methyl hydrate in the gas.
Old 06-18-2009, 06:13 PM   #9
BMWnoob
anybody want to help me do something on the weekend lol...
methyl hydrate.. google tells me this is antifreeze... i just pour some into the gas tank.. is this going to cause harm? should i be worried that the car actually failed etest? i don't mind spending some money to "fix" whatever needs to be fixed since i've invested into this car already
thank again everyone!
Old 06-18-2009, 06:19 PM   #10
Idle Air Control
Should be #5 I believe, the e30 guys can verify.
http://www.realoem.com/bmw/showparts...13&fg=15&hl=33
Old 06-18-2009, 06:26 PM   #11
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
^^ICV. Idle control valve. Probably not the cause for rich idle though. Rough yes. I would bet it's just the O2.
Grow up and move on.
Old 06-18-2009, 06:50 PM   #12
e30jones
methyl hydrate.. google tells me this is antifreeze... i just pour some into the gas tank.. is this going to cause harm? ...
Gasline antifreeze, not just "antifreeze". Burns cleaner and hotter than gas, as it's alcohol IIRC. I'd probably try and fix what's broken first, methyl hydrate as a last resort.
Spark plugs, adjust your valves, O2 sensor to start with, don't forget a new air filter if it hasn't been done.
Just a though, if it's rich at idle but not off idle, could it be the TPS idle switch not connecting properly (ie/ car isn't going into the idle loop, dumping too much gas at idle?) With the car off, open your hood and move the throttle butterfly from closed to open, and then let it close again. Listen closely to see if you can hear a quiet click. If no click, it's not hitting the idle microswitch.
e30jones is offline   Reply With Quote
Old 06-18-2009, 08:19 PM   #13
BMWnoob
o2 sensor is new, spark plugs are new.. my dad smells gas fumes on the left side of the car.. any ideas?
Old 06-18-2009, 08:29 PM   #14
5thseries
biggerthen3
Check the pcv valve
Red line
High grade fuel
Hows the catilic
and yah =)
5thseries is offline   Reply With Quote
Old 06-18-2009, 08:54 PM   #15
BigD
the misanthropist
BigD's Avatar
You know this because you were told so or because you've paid to have these things replaced?
