Old 06-17-2009, 11:07 AM   #1
davericher20
black and blue
davericher20's Avatar
anyone?
ever round out the nut on the oxygen sensor?
I did.
Can't get it off now, borrowed some super duper penetrant and see if that will make it an easy out.......but it's completely rounded off.......****.
Torch?
Old 06-17-2009, 11:12 AM   #2
Torch.
Old 06-17-2009, 12:21 PM   #3
Fel
Not Banned
Fel's Avatar
Vice grips? I dunno..
Old 06-17-2009, 12:34 PM   #4
BigD
the misanthropist
BigD's Avatar
Get a pipe wrench on it.
Old 06-17-2009, 12:37 PM   #5
Quack
Wheelman
Quack's Avatar
use a torch, then with a pair of large vise grips or channel locks you might be able to turn it.
Old 06-17-2009, 02:30 PM   #6
jays325is
Yeah he used a pair of vice grips, and that's what rounded it off in the first place.
Dave, if you need a propane torch, I have one if you don't.
jays325is is offline   Reply With Quote
Old 06-17-2009, 02:50 PM   #7
Ceeker
propane torch is like drinking "light" beer. Won't do shit. need something hotter or OA torch. then with channel locks or pipe wrench or vise grips reef on it!! should twist out no problem.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 06-17-2009, 04:23 PM   #8
davericher20
black and blue
hmm, thanks guys
Yeah Jay thanks man I might take you up on the torch, it it doesn't do shit then I'll get something hotter I guess.
Old 06-17-2009, 04:30 PM   #9
SamE30e
SamE30e's Avatar
Oxy torch and vise grips. Probably won't come off any other way, but don't use it after you heat it up with the torch, it's useless afterwards.
85 325 - Turbo M52B28.
Old 06-17-2009, 05:04 PM   #10
davericher20
black and blue
don't use the oxygen sensor after I heat it up? Is that what you meant?
Old 06-17-2009, 06:28 PM   #11
E30M42cab
Parts Hoarding Specialist
E30M42cab's Avatar
yes, don't re-use the 02 sensor, and don't use a propane torch, it won't do shit. Propane won't get it hot enough. If it's in there really badly, just cut the wire and leave it. put a new hole in the pipe, weld in a new threaded insert and use anti-sieze (the kind that is safe for 02 sensors) and install a new 02.
Grow up and move on.
Old 06-18-2009, 08:37 AM   #12
Mister
Heat up the o2 sensor with a torch,propane will work,its not about the heat its actually the cooling that breaks them free. Heat it up and purge right away with really cold water,lock the grips down and get her out. it'll work. Mister
There are two kinds of drivers out there.BMW drivers and all the !@#$% Rest. U want to catch a bimmer ,u better have a bimmer.
Mister is offline   Reply With Quote
Old 06-18-2009, 11:46 AM   #13
adam325i
adam325i's Avatar
just dont use regular anti sieze on it, it will make it worse, you need the coppercrap.
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 06-18-2009, 12:21 PM   #14
Pipe wrench wins, everytime. Some call them monkey wrenches. There is no way it won't get it out. Just use more leverage.
Old 06-18-2009, 01:05 PM   #15
sic///M
+1 for pipe wrench
sic///M is offline   Reply With Quote
