Old 06-17-2009, 12:57 AM   #1
El Gato Liso
El Gato Liso's Avatar
Slotted rotors question....
I had to give it second thought....but was way too unsure as i've seen both before.
and should i have the rear rotors go in the same direction as the front rotors?
thanks!
A or B *front LEFT strut!!!*
R.I.P. E30
Old 06-17-2009, 07:18 AM   #2
Quack
Wheelman
Quack's Avatar
it really depends on the manufacturer, I had slotted rotors on my 540 and when I was installing them there was a L & a R stamped on the rotor, after installing it looked like the pic "B", do you know the brand of rotor you bought?
Old 06-17-2009, 08:08 AM   #3
Duct_Taper
Sticky
Duct_Taper's Avatar
I would have thought A, assuming you're trying to get the brake dust/gases to go outwards towards the wheel and not inwards towards the hub.
Edit: And whichever way they go, the rears should be the same as the fronts.
Duct_Taper is offline   Reply With Quote
Old 06-17-2009, 08:51 AM   #4
Mister
look at pic b,as the wheel rotates the slots clean the surface of brake pads yes.
what would pic A do for yah?nothing slots would be on the wrong angle for rotation unless you drive backwards down the road
crossdrilled for the street good, slotted and crossdrill race application,you go thru a ton of pads. .Mister
There are two kinds of drivers out there.BMW drivers and all the !@#$% Rest. U want to catch a bimmer ,u better have a bimmer.
Mister is offline   Reply With Quote
Old 06-17-2009, 09:29 AM   #5
It won't matter, as long as the rotor vents the proper way. At the rear it won't matter since the disc is solid anyways.
Old 06-17-2009, 10:43 AM   #6
xlash
Still learning....
xlash's Avatar
It's A. As someone one said the setup in A would allow the brake dust, gases to move outwards.
Just my 0.02, slotted/cross drilled rotors really only add aesthetic value. These 2 have been grandfathered in from the olden days when mechanical engineering had to substitute for materials engineering. You want to maximize the area of contact between the brake pads and rotor and slotting and drilling reduces that. And what's worse is you actually increase brake dust by using slotted/cross drilled rotors, thus reducing the lifespan of the pads. I haven't experienced cross drilled rotors but I have heard that they start cracking faster than plain rotors as well.
If you want higher performance rotors go with vented rotors. They dissipate gases and heat a lot faster without hampering the life of the pads.
Selling: Winter Tires/Wheels for E36/E30
xlash is offline   Reply With Quote
Old 06-17-2009, 11:11 AM   #7
Quack
Wheelman
Quack's Avatar
the people that are guessing it's "A" you don't really know do you, I already said it's really depends on manufacturers, some have it likepic "A" & some like pic "B", I've installed many slotted rotors & they vary from manufacturer, look at DTM race cars, they have their rotors like pic "B".
Old 06-17-2009, 02:36 PM   #8
slemmer
Driving in the fast lane
slemmer's Avatar
I don't think they really make any appreciable difference on the street. Just like video cables - pay the $$$ for a 24 ct plated end or less for nickel plated. You'll still see the picture and probably won't know the difference unless someone told you. Plus, you'll needa scope to see any miniscule differences.
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 06-22-2009, 02:42 PM   #9
juzer
7000 RPM
juzer's Avatar
install them like B photo and forget them
juzer is offline   Reply With Quote
Old 06-22-2009, 03:21 PM   #10
Mine are installed like A.
The theory is that B gives it a bigger "Bite".
Old 06-22-2009, 06:58 PM   #11
5thseries
biggerthen3
Lol nice art
it wont matter
but if you want set them up like "a"
5thseries is offline   Reply With Quote
