Old 06-11-2009, 08:44 PM   #1
///MsAniTy
Where to buy detailing supplies in the GTA???
My buddy bought a simoniz buffer and we wanna try it out on his ride. We want to know where to find polish and wax pads for the buffer which i think is 10inchs in diameter. we would also like to buy some good polishing products for the car.
Also if anyone knows of any place in mississauga that would be great
///MsAniTy is offline   Reply With Quote
Old 08-11-2009, 04:32 PM   #2
daveyto
daveyto's Avatar
That buffer is pretty crappy and can burn paint....i know...I have one
daveyto is offline   Reply With Quote
Old 08-11-2009, 04:49 PM   #3
Ceeker
any rotary buffer can burn paint. You have to know how to use it so that you DON'T burn the paint. :-) That comes with experience more then anything else. That with the right buffer and application (knowing which pad and product to use for what result) can make your car look like glass or burn through to the metal. Get yourself a crappy hood or trunk lid with faded paint and practice first before you give your buddy a stroke!!!! LOL..
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 08-12-2009, 11:59 AM   #4
Gamite
Gamite's Avatar
I buy all my supplies from eshine.ca
www.gamite.net
Old 08-12-2009, 12:02 PM   #5
slemmer
Driving in the fast lane
slemmer's Avatar
And test in an inconspicious place
'15 Ford F150 Lariat SCSB 4x4
'04 645cic
'00 740i Sport
Old 08-12-2009, 01:32 PM   #6
e36nut
You've really burned through the paint? What were you using when doing this, a floor buffer? You can buy all the Simoniz pads at Canadian Tire or Part Source stores. I have a Simoniz 10" polisher as well and it works great.
e36nut is offline   Reply With Quote
Old 08-12-2009, 01:35 PM   #7
Gamite
Gamite's Avatar
the 10" random orbital lacks the speed and power to polish correctly. If you only want to apply polish, then this is sufficient. However if you want to correct paint e.g: swirls, you need something more powerful.
www.gamite.net
Old 08-12-2009, 02:08 PM   #8
Ceeker
if you want to learn and do a seriously great job. Get yourself a makita multi speed polisher. It's lighter then most and more easy to use then other name brands. Not an orbital. it doesn't do anything except vibrate and gets you all excited..lol. What you get from crappy tire is for the novice. it isn't professional. if you are looking for professional products crappy won't do.
Ferecla products are what most serious body shops use - which I use/used in the past and knowledge of working with these products is required. There are others out there which also work great which I have used, again required a know how of the product and not just the machine. Most people like using sponge and cotton pads because they are safer and cut less. But wool is the way to go if you want to clean the paint up quick and effectively. This is a skill which requires patience, "FINESSE" and knowledge through learning from someone with experience. Experience is the greatest teacher!
Those who don't make mistakes never went the distance, or won't admit to making them.
Old 08-12-2009, 05:12 PM   #9
W2WDETAILING
i have to agree with you! but simoniz makes a rotary which i actually have its half the price of the makita and its variable speed. for a novice its good for a pro its not the best due to its weight. the pads at ct are garbage. try napa or your local auto supply place. eshine is also a great place!
Old 08-12-2009, 06:35 PM   #10
daveyto
daveyto's Avatar
I also have the simoniz rotary and it seems cheap and wobbly...but a fraction of the cost . It appears to do the job...but I realized I could do some real damage....anybody know how I would polish smaller areas? Should I buy smaller pads?
Say...4 inch?
regards and thanks for all the usefull info...
Old 08-12-2009, 06:41 PM   #11
Ceeker
yes, you can buy the Farecla brand sponge wheel. The foam is fused to the backing plate. It is soft enough to conform to corners - 3.5 in. in diameter. You can also get the velcro backing Maguire's pads - also in foam approx diam 4 in. that will work. Anything you can't get to by machine can always be done by good o'l elbow grease - hand polish.
Note: if anyone should get their hands on the Ferecla G3 or G10 compound be careful to tape off or cover all moldings as it will stain them. Some other brands of compound also have the same effect.
The other machine available, which costs more the Makita is Milwaukee. This one is much heavier which actually can work to your advantage if you know how to let the machine put pressure using its own weight - can help to do the work you would normally need to do with pressure from your hands.
Old 08-12-2009, 08:58 PM   #12
daveyto
daveyto's Avatar
thanks ceeker!
