Old 08-02-2009, 05:47 PM   #16
DR.ZED
Okay, I'm finally done. Let me first say that lifting the rear diff (anybody know what a LSD diff weighs?) on my back and jackstands was NOT FUN!!!!
After everything was put back together I went out for my first LONG drive yesterday. Car is phenomenal and very tight. I completely forgot to get before pictures but I tried to have the car aligned and the alignment shop told me nearly 2.8 deg neg on the passenger and 1.1 or so neg on the drivers. It was obvious and actually pretty silly looking from the rear when you looked at the car from the back end. After the work I'm dead nuts even on both sides.
Some interesting notes when doing this project. The only work I didn't do was push out the axle carrier bushings and the diff bushing. The shop the did those three said it took them 2 hours of torch, hacksaw and press. They definitely earned the $100 to do this.
Make sure to clean out the receiving hole in the body where the axle carrier bushing goes into. I took my old bushing which still had a proper rod still attached (one broke) and cleaned it and used it as the template for how easily it went into the receiving hole. I used sandpaper to clean it.
Getting the diff up even 18" was a HUGE pain with its weight and odd size. I owe my wife big time for getting greasy with me helping.
Nearly all the bolts that go back have to be replaced as they are all lock nuts. To do a final torque of the control arm bushing bolts I put a jack under each control arm for the final torque and let the body rest to simulate ride height.
Have fun with the dumba$$ sway bar end links in the rear. They push in and are a major PITA to squeeze the sway bar through the small rubber opening (even when greased). Again with suspension loaded I tightened the lower nut for the end link.
... so here are the pix. (control arm bushings from AKGmotorsports and worked awesome)
Cam G.
85 325e M5
07 Honda Shadow Spirit 750
Old 08-02-2009, 05:48 PM   #17
DR.ZED
Cam G.
85 325e M5
Old 08-02-2009, 05:49 PM   #18
DR.ZED
Now for the best test of all!
Shannonville next weekend and Mt. Tremblant for two days end of Aug!
(.... but first to fix that heater core which let go last night.... )
Cam G.
85 325e M5
Old 08-02-2009, 06:41 PM   #19
All you need for the diff is a floor Jack and it becomes a one man job, I wouldn't ever try lifting one into place.
Old 08-02-2009, 07:49 PM   #20
e30_kid89
The Afro-stig
e30_kid89's Avatar
2 hours to change the diff and subframe bushings......OFF the car? I don't know thats kinda long..If you really wanted you could of changed each side in that time. But it's all good..It's done!
I reallllly wanna make some to make some track days either this or next month, hopefully I'll see you out there!
Old 08-03-2009, 08:44 AM   #21
DR.ZED
The problem with jacking it up with a floor jack is that mine didn't have the height necessary. I then tried to balance it with two pieces of wood and got the height but you can imagine what happened next.
I'm going to have to invest in one of those super long super high reach jacks.
Cam G.
85 325e M5
Old 08-03-2009, 10:12 AM   #22
richie_s999
holy shit think you should look into that exhaust pipe for the next project...how many times did the prevous owners weld new peices???? WOW...anyway glad to here you got all that done, I am so not looking forward to a full suspension bushing redo next spring, but am sure the cars handling alot better now!!
Old 08-03-2009, 07:46 PM   #23
dble Trouble
TAKE IT TO THE TRACK
dble Trouble's Avatar
If you're looking for a great track day come out to the Trillium event on the 23rd of August Sunday. There are going to be literally a tonne of e30's out. Not that it's limited to e30's but lots are going to be there.
Old 08-03-2009, 10:17 PM   #24
richie_s999
Already talked to Cam, you'll meet him on the 9th, he's away instructing at the track in Quebec that weekend
Old 08-04-2009, 12:15 AM   #25
dble Trouble
That sucks. ^^ See you on the 9th. Hey Rich my wife is coming too, so Lori better be there!
