Old 06-04-2009, 02:41 PM   #1
Sergsam
Master
Sergsam's Avatar
Question How reset service light?
Hello
Any body can give advice how I can reset service light without visiting shop?
I have E39 2001.
Sergsam is offline   Reply With Quote
Old 06-04-2009, 03:46 PM   #2
Dado 540
Dado 540's Avatar
On the round plug under the hood all you need to do is take a piece of wire and plug it into pin 7 and pin 19(ground)
Do this with ignition off. Once you have the wire in place turn the ingnition to position 2 but dont start the car. If you do this for 4 seconds Oil Service is reset, if you do it for 10 seconds Inspection Service is reset. Turn ignition to off and Viola!
There must be a few write ups on this. But that how you do it.
E39 540i Sport
Old 06-04-2009, 04:10 PM   #3
Sergsam
Master
Sergsam's Avatar
Thanks buddy
But I have E39 after September 2000.
Thats means model 2001 and up. I wrote this information.
Those car doesn't has old style round diagnostic connector under hood.
Old 06-04-2009, 04:21 PM   #4
mazdaRXwhat
so you have OBD 2. Come to a Friday night meet sometime..sometimes ppl show up with the diagnostic tool to reset it.
mazdaRXwhat is offline   Reply With Quote
Old 06-04-2009, 04:47 PM   #5
Sergsam
Master
Sergsam's Avatar
I will be in Bramptom Saturday midday. In what Place?
Old 06-05-2009, 01:11 AM   #6
Ike
You didn't give any details of the specific engine in your car -
If it is a six cylnder engine with the round multi pin connector for engine diagnosis you simply need someone to sit in the car and turns the key to position 2 (without starting the car). you then use a single piece of wire connected to terminal #7 and touch it to engine ground for ten seconds. Turn the key to off and check if the reset has occured. The doors must be closed otherwise it will not reset.
If you have an eight cylinder engine - like a 540i you use the following procedure:
- Iginition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset.
Good Luck.
Ike is offline   Reply With Quote
Old 06-05-2009, 01:35 PM   #7
Sergsam
Master
Sergsam's Avatar
Thanks Ike
Second way works.
But is not necessary to have 540. This way is suitable for any E39 after September 2000.
I have a description of second procedure, but with missing one step. Therefore it didn't works.
Now I have full right description.
Thanks.
Old 06-09-2009, 12:10 PM   #8
BoostedMX
All Eyes On Me
BoostedMX's Avatar
would that work on a 97 540i?
97 E39 540i
BoostedMX is offline   Reply With Quote
Old 06-09-2009, 02:20 PM   #9
Sergsam
Master
Sergsam's Avatar
NO.
You have a round connector. Therefore you have to use pin#7 , grounded it. Just read previos post.
Old 01-22-2010, 09:29 PM   #10
Anchorsmash
do you know how to reset it in a 318is 97'
Anchorsmash is offline   Reply With Quote
Old 01-24-2010, 03:56 PM   #11
Sergsam
Master
Sergsam's Avatar
Unfortunately I forget this.
I remember that for reset service light you can connect +positive pin #11 or 14 with some pin, probably #7.
Other way to grounded it.
But, I am not sure regarding pin number!!!!!!
Please, check wire diagram for service connector!!!!!
And check precedure, may be some body else answer for your question.
This I used for all car before 1999.
Old 01-24-2010, 04:17 PM   #12
Ceeker
Pin #7 to ground with ign key in access or step 1 position. NOT with the car running. hold ti'll lights reset and you're done.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
