Old 06-02-2009, 02:16 PM   #1
black bnr32
black bnr32's Avatar
HID no worky
Hey guys,
I need to replace the passenger side HID setup on my car, but I can't figure out what brand/set up I have. Its a 35W 8k set up of some sort. My car is throwing the low beam code and I suspect its because I repaired a cut wire.
Ideas?
black bnr32 is offline   Reply With Quote
Old 06-03-2009, 12:13 PM   #2
mech9T8
mech9T8's Avatar
Funny, my pass side went out a while ago too.
Couple of things you should check if you haven't already.
1) Check all connections
2) Check fuses
3) Is the ballast bad or the bulb. You can swap sides to check this. Take ballast from driver side and plug into pass side and vice versa.
I determined my bulb was bad.
I bought a set of bulbs from Proprone. He's a sponsor here.
mech9T8 is online now   Reply With Quote
