Old 05-28-2009, 02:23 PM   #1
apriliadr
failed e-brake replacement of shoes
so I finished replaces my e-brake shoes, set the shoes snug against the drums so that there is some drag., I also adjust parking brake handle, tighten done and test to see if it works. Car just kept rolling back on unlevel surface. Did I miss a step?
apriliadr is offline   Reply With Quote
Old 05-28-2009, 02:40 PM   #2
dannyb
are you sure your cable is still good?
dannyb is offline   Reply With Quote
Old 05-28-2009, 02:43 PM   #3
Ceeker
I believe they have self adjusting capacity. Drive the car backwards down the road and do some heavy braking. do this a few times it does help adjust he emerg brakes. Unless I am mistaken...
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 05-28-2009, 02:58 PM   #4
You definitely are mistaken (or smoking crack)....the e-brake mechanism has no connection to the hydraulic brake line.
How did you adjust the parking brake handle? Maybe you adjusted it the wrong way? and made the cable too loose ?
Also did you ensure the little piece at the bottom where the cable comes in was free and not seized? If that small part is seize your brake shoes won't budge.
Old 05-28-2009, 04:40 PM   #5
apriliadr
what piece at the bottom? I didn't check that part, what does it look like? pics preferred.
thanks
Old 05-29-2009, 09:41 AM   #6
Part #5.
Old 05-24-2010, 07:17 PM   #7
Brent
Brent's Avatar
If that part is seized, first, how do you get it off, and second, if you replace it, will a seized brake generally work?
From Eyesore to Heat Score
Brent is offline   Reply With Quote
Old 05-24-2010, 07:43 PM   #8
Ceeker
oh wait! come to think of it... yes! I think I was smoking crack at the time...lol.
Old 05-25-2010, 12:34 AM   #9
LOL jeezus Ceeker I swear you just make stuff up.
Part #5 almost always seizes up, and unless you know that its supposed to move it looks like it doesn't. Rip it back out, soak it in oil and see if it frees up.
Old 05-25-2010, 06:42 AM   #10
Brent
Brent's Avatar
I've been pulling on it by hand, is there a tool or any advice that will makee it come off easier? Or do I just have to keep yanking on it? Does it have a catch or anything that needs to be undone to allow it to come off?
Old 05-25-2010, 07:21 AM   #11
dannyb
#5 should be held on by the #6 pin, that can be a pain to take off
Old 05-25-2010, 08:05 AM   #12
Ceeker
Yeah, I kinda like it..keeps people on their toes...LOL
