Old 05-12-2009, 12:19 PM   #1
MLue1
MLue1's Avatar
WARNING:V8 Timing Chain Tensioner & Guide Rails
I normally don't do cross post between forums but in this case I think it necessary. The E38 and X5 guys have been seeing some engine noises and other problems related to Timing Chain Tensioner & Guide Rails failures, since the V8 in our E39 is the same, this applies to our cars as well.
My car sounds fine so I will be doing the replacement of the lower timing chain tensioner as a maintenance item, just soon as I receive the part from Jared at EAC Tuning.
http://forums.bimmerforums.com/forum...hain+tensioner
http://forums.bimmerforums.com/forum...d.php?t=873820
Mark
'99 E39 540iT
Old 05-12-2009, 01:17 PM   #2
TheMadChigga
TheMadChigga's Avatar
Another '99 owner, I'm going to do it this week, mine is making noise already and its really getting to my nerves with the noise.
Old 05-12-2009, 01:44 PM   #3
martinM5
wow that looks like a HUGE job...
2009 BMW 335i Coupe Msport LeMans Blue on Sexy Saddle
2016 X3 28d Msport SpaceGrey on Saddle
martinM5 is offline   Reply With Quote
Old 05-12-2009, 01:52 PM   #4
myndgone
..... kLaSSe~1 .....
myndgone's Avatar
Send a message via MSN to myndgone
I think you're supposed to replace the tensioner every 80K anyways, no?....
myndgone is offline   Reply With Quote
Old 05-12-2009, 02:32 PM   #5
MLue1
MLue1's Avatar
I don't think it is listed but I think if it had lasted this long on my car if I replace it I should be good to go. The theory is that if the chain is prevented from going slack the guides should remain intack for a longer peroid of time. The new chain tensioner has a longer effective length so hopefully it's more effective in taking up any excess slack in the chain.
Mark
'99 E39 540iT
Old 05-12-2009, 03:00 PM   #6
Dado 540
Dado 540's Avatar
I've gone through this on bimmer forums as well, and its scray.
Mark you have a pic of the tensioner?
Here some scary photos.
Is this the chain guide rail that deteriorates (red arrow)?
E39 540i Sport
Old 05-13-2009, 02:08 AM   #7
rzrdxl
Thanks for the heads up, Mark!
rzrdxl is offline   Reply With Quote
Old 05-13-2009, 10:04 AM   #8
careless7
Drivin' new whips weekly
careless7's Avatar
Who engineers these things? And do they still have a job?
careless7 is offline   Reply With Quote
Old 05-17-2009, 02:24 PM   #9
MLue1
MLue1's Avatar
DIY and Part Info
Here is a pic of a new Lower Chain Tensioner for the M62TU engine.
Use this DIY guide:
http://forums.bimmerforums.com/forum...&postcount=151
Edit: Right now Autopartsway has good prices and availability on the Lower Timing Chain Tensioner 11317531813 and the Gasket Ring 07119963355:
http://www.autopartsway.ca/AutoParts...er=11317531813
http://www.autopartsway.ca/AutoParts...er=07119963355
Mark
'99 E39 540iT
Old 05-17-2009, 02:48 PM   #10
myndgone
myndgone's Avatar
Pretty easy to replace!
Old 05-21-2009, 11:33 AM   #11
Oyster
Send a message via MSN to Oyster
Thanks for sharing links and discussion. I have this on my to-do list
Oyster is offline   Reply With Quote
Old 05-21-2009, 07:41 PM   #12
Qube
Sounds like a rattle can of paint. I've got a whine, which I think is from the fan clutch.
Qube is offline   Reply With Quote
Old 05-22-2009, 08:23 AM   #13
Trouble65
Tensioner and guides should last you 200,000Miles if not more, depending on your driving sytle and oil used. Your timing chain will outlast your car.
Trouble65 is offline   Reply With Quote
Old 05-22-2009, 11:39 AM   #14
MLue1
MLue1's Avatar
The key word is "should" by most accounts or directly comparing the old part to the new, the new part has been modified to have a longer effective operating "reach" to further compensate for wear or chain streatch.
Mark
'99 E39 540iT
Old 05-22-2009, 01:52 PM   #15
Dado 540
Dado 540's Avatar
I can't understand why the guides are not made from more tolerant material. You would assume that's something you would never have to worry about.
E39 540i Sport
