Old 05-22-2009, 10:17 AM   #1
cirrusblau
Sunroof Stuck
So I got home from work yesterday and the sunroof got stuck about 4" from wide open while closing it. All the documented sunroof adjustments and such require the sunroof to be in the vent position...
I've tried to take as much apart as I can, but can't get too far with the sunroof mostly in the roof. Any ideas?
The motor and such are okay; I'm thinking something is jammed.
Old 05-22-2009, 12:30 PM   #2
Ceeker
You may have to close the sun roof and then open in the vent position to see if anything is stuck in the tracks. You may have dragged something that was already there back into the guides. If you can do this you can drop the SR cover down and without having to open the SR you can slide the cover back into the body to expose the inner area of the SR.
2nd Option: if the first didn't work. You should have an allen key tool in the trunk took box.
Take the inspection panel out and manually crank the sun roof back into place. and then try the 1st option over again. good luck
One last thing to check. you may have snapped the cable which retracts and closes the roof.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 05-22-2009, 03:58 PM   #3
cirrusblau
Thanks for the reply, but the sunroof is stuck open, ie. it doesn't close and it can't reach the vent position.
As stated earlier, the motor is good and even assisting the sunroof (pulling it), it doesn't budge. Cranking it manually would yield the same results as using the motor.
Cables are both good.
Any other ideas? This is gonna be a tricky one... I've got spare parts from my parts car, so a destructive solution would be possible if I could figure out a way that would work.
Old 05-22-2009, 06:29 PM   #4
e30jones
I have the same problem, but mine is stuck shut all the way. I think one of the arms has broken. My plan was to cut a hole throught the top of the panel so I can get an allen wrench in to undo the bolts that hold it to the arms, then lift the entire panel out. I guess you could also try to rip the sunroof liner out too if you can access the front of it, and then see what you can see from there. Either way, you're gonna need new parts.
e30jones is offline   Reply With Quote
Old 05-22-2009, 06:39 PM   #5
cirrusblau
At least yours is stuck shut! I'm not driving my car at the moment because of the theft/weather issues.
I think I might try ripping out the sunroof liner... I've got a spare.
If that doesn't work, might end up removing the headliner to access the rear portion of the sunroof... that's a PITA, I'm hoping it doesn't come to that
Old 05-23-2009, 01:34 AM   #6
325isStephen
Drifter
If your good at pulling windows, it won't be hard to drop the rear end of the head liner, just pull the rear quarter windows and the rear window and you should be fine.
But if you have a spare sunroof liner I would start there.
Steve
Old 05-24-2009, 09:54 PM   #7
cirrusblau
Good news everyone, the sunroof freed up when I riped out the sunroof liner. Still not sure exactly what hung up, but it's sliding freely again after a good clean and lube.
