Old 05-20-2009, 10:52 PM   #1
jamison67
E30 POWER
jamison67's Avatar
racing springs
i was looking into the adjustiblecoilovers from cosmo racing,the sprig rate on them is 8kg in the frt and 10 kg in the back,,,,,what i want to now is ,is that a stiff spring causei want to put som real deep dish rims on here and i dont want it to rub on the outside lip,,,,will these do the trick for me,,,,if not what do u guys reccomend for me
thanks
jamison67 is offline   Reply With Quote
Old 05-21-2009, 06:04 PM   #2
adam325i
adam325i's Avatar
Take a look at this, higher the number stiffer the springs are.
http://www.e30tech.com/forum/showthread.php?t=40472
90 325i 4dr Winter fun
90 325i 2dr Summer/track car
87 325i 4dr Parts
adam325i is offline   Reply With Quote
Old 05-21-2009, 08:11 PM   #3
kg/mm to lbs/in
16 = 896
15 = 840
14 = 784
13 = 728
12 = 672
11 = 616
10 = 560
9.0 = 504
8.5 = 476
8.0 = 448
7.5 = 420
7.0 = 392
6.5 = 364
6.0 = 336
5.5 = 308
5.0 = 280
4.5 = 252
4.0 = 224
3.0 = 168
2.0 = 112
Old 05-21-2009, 08:40 PM   #4
matty.dc
matty.dc's Avatar
does anybody know the apex spring rate for the e30's? i cant find it anywhere.
2013 Ford Edge - Daily Driver
Old 05-21-2009, 10:47 PM   #5
e30_kid89
The Afro-stig
e30_kid89's Avatar
^^^ It's because it's that bad... I think its the same or a bittt stiffer than stock.
Old 05-22-2009, 12:28 AM   #6
matty.dc
matty.dc's Avatar
lol thank god the roads out here aren't too bad
Old 05-22-2009, 03:47 AM   #7
echo
e30 slave
Don't run race rates on a street car. You're just posing if you do. Unless you know what you are doing and very carefully choose a rate for your driving style and roads.
A good street setup will see you right. Get coil overs by all means, but choose a sensible rate and just flare the guards.
echo is offline   Reply With Quote
Old 05-26-2009, 06:43 PM   #8
jamison67
E30 POWER
jamison67's Avatar
so what r ur recommondations ,,,,do u guys think that the cosmos coilovers will do the trick,,,,,according to that list of spring rates they seem to be pretty stiff (the higher the pound the stiffer the rate is)
