Old 05-20-2009, 05:16 PM   #1
Boxer2
The OPP loves my M5
Boxer2's Avatar
Power steering issue, 86 535i
Hi guys,
I'm having some problems with my PS, and was wondering if anyone could help.
Symptoms are it is very noisy, and the fluid in the reservoir foams up/looks like it's boiling, over the rim of the container, and the car is very hard to steer.
any ideas on a possible solution would be great.
thanks in advance.
Rene
My Garage:
1986 328is (M20 Stroker)
1986 535i (5sp all original)
1990 325iX (Mint 5sp all original)
1989 325iX (Winter auto X car)
1991 M5 x2
1988 M6
2001 740i (Supercharged)
1999 528iT (summer DD)
2004 X5 3.0i (winter DD)
Boxer2 is offline   Reply With Quote
Old 05-20-2009, 05:21 PM   #2
Ceeker
your pump is shot..change the steering pump...rack could also be binding due to the problem as well.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 05-20-2009, 07:14 PM   #3
5thseries
biggerthen3
If it bubbles, does that not mean the line has to be bleed.. meaning some kind of puncture? Or like ceeker said.. the pump is shot,
5thseries is offline   Reply With Quote
Old 05-20-2009, 07:40 PM   #4
MANDD
Autobahn East
You will need a pump, the rear plate fails causing the pump to cavitate due to transient vibration of the shaft.
Be sure to flush the steering box.
Mark.
Old 05-21-2009, 09:56 AM   #5
Boxer2
The OPP loves my M5
Boxer2's Avatar
Thanks guys,
I did do check around for any leaks, but there wasn't any, so I'm not to sure it's as simple as bleeding the system.
will pull a pump off the parts car and see what happens.
My Garage:
1991 M5 x2
1988 M6
