Old 05-18-2009, 10:18 PM   #1
JonE39
e39 Third Brake Light Melted
I had a "check brake light" warning on for awhile but the light still worked. Then the light quit working so I pulled the bulb socket out. The bulb itself is melted into place in the socket and is drooping slightly. I'm considering buying a new socket and bulb but this will just be a waste of money if there is something else that is wrong. Anyone else have this happen?
JonE39 is offline   Reply With Quote
Old 05-18-2009, 11:11 PM   #2
Dado 540
Dado 540's Avatar
If you are reffering to the brake light located under the rear glass, i have noticed that the plastic around the bulb housing has a bit of melted plastic. At the time the bulb burned out and i opened it for a replacement, and seen the melted plastic (nothing extreme). I just replaced the bulb and popped it back i place. Havent checked it since (been over 2 years).
Can anyone else chime in on this one?
E39 540i Sport
Old 05-19-2009, 02:11 AM   #3
JonE39
Well I've tried to remove the bulb but it is fused into place.
Old 05-19-2009, 12:45 PM   #4
Dado 540
Dado 540's Avatar
^ haha thats more like it!
E39 540i Sport
Old 05-21-2009, 10:21 PM   #5
overlordjd
I had the same thing happen to me but eventually got the bulb out.
To avoid any future issues I ended up just changing both the holder and bulb.
It was not too costly from Parkview BMW.
No problems since.
overlordjd is offline   Reply With Quote
Old 05-22-2009, 08:18 AM   #6
Trouble65
You learn something new every day. I have to go and look at my car.
Old 05-22-2009, 11:45 AM   #7
MLue1
MLue1's Avatar
No problems since.
Are you sure it is melted, when I changed my license place bulb I thought the connection had melted as well be as it turned out it was only a bit of corrosion on the bulb and contacts. I cleaned up the contact and applied some dialectric grease and everything has been fine.
Mark
'99 E39 540iT
Old 05-22-2009, 07:04 PM   #8
overlordjd
You should never have condensation on the 3rd brake light due to its position not being exposed to the exterior of the car. If you do, then you have a serious issue on your hands. This is caused by poor connections from the bulb and the contact which generates heat and overtime may melt the plastic holder.
