05-18-2009, 05:10 PM
#1
Ciao Ciao
Car: e39 528i / e38 740iL
HELP! E38(740iL) won't start..starter?fues?relay?...
'97 740iL...the car won't start. The eletronics inside seem to work but the engine won't start. Tried jumping it but nothing. I thought maybe it was the starter so i took that out hooked it to a battery and the starter works. I put the fault code tool and i get a EWS Input - EWS=Drive away Protection (Alarm System)?. Is there a fues or relay problem? has anyone had this problem, anyone that can help will be so appreciated, thank you
R.I.P. e39 528i Sport - "curri curri 'ca ca t'aspiettu"
05-18-2009, 09:18 PM
#2
Car: 330ci SC, M5 Touring
Just had the same problem on my 740il today, went to start but wont cranck...all power is on. Didnt have time to investigate the problem...
05-19-2009, 09:15 AM
#3
Autobahn East
Car: 745Li/850i/LR Disco2
Do you have a second key? If so try it otherwise you may need to re-align the EWS to the DME.
Mark.
05-19-2009, 12:59 PM
#4
Ciao Ciao
thanks mandd ....I can't try the second key because i decided to have my alternator checked since i had taken the starter out to check it.
Sorry if it migth sound ignorant, but i've never had problem with the car before or these kind of problems with either bmw i have, but how would i re-aline the EWS to the DME? and if that is the issues, what caused it?
05-19-2009, 01:34 PM
#5
Autobahn East
It is not uncommon for the EWS to scatter the rolling code, typically when the car battery is low on charge. Also another issue on the E38 is the neutral safety switch.
The down side to aligning the EWS is that you will need to tow the car to a shop with the correct equipment to perform this procedure.
There is a few options for you in the immediate Toronto area such has,
Bimmex
Bimmersport
Lakeside Motors
Mark.
05-19-2009, 07:49 PM
#6
Car: E38 740iL
to the OP,
I had a similar issue, where all electronics are working but I wasnt even getting a crank.
In the end, I had to replace my fuel pump.
05-21-2009, 08:42 PM
#7
Ciao Ciao
alternator,starter, fuel pump are good, tried other key nothing changes...things light up but no start...MANDD, neutral safety switch?
05-22-2009, 12:19 PM
#8
Ciao Ciao
where is the starter relay located on the '97 740iL?...
is it behing the glove compartment like the 540i?
05-28-2009, 08:09 PM
#9
Car: E38 740iL
Bella5icilia, if you post in the 7 Series section of bimmerforums, you WILL get a better idea, and faster...
05-28-2009, 10:51 PM
#10
1999 BMW 740i BMW 2000IT
Car: BMW740i and BMW X5
Just have it towed to Bimmersport  you will not be disapointed in the service and care that your car will receive.
BMW 740i - BMW X5 - BMW Mini Cooper S
06-02-2009, 10:03 PM
#11
Car: E38 740iL
I'll give a +1 to that!
06-08-2009, 01:08 PM
#12
Ciao Ciao
thanks everyone for your help, i had the car taken in to a shop here in michigan, and i'll get the car tomorrow. the problem was EWS module.
06-08-2009, 05:10 PM
#13
Autobahn East
I did not realize that you were in the U.S., glad you got it looked after.
Mark.
