Old 05-17-2009, 11:45 AM   #1
Max_VQ
Max_VQ's Avatar
A/C Repair
Does RPM or Bimmersport do AC repair?
My compressor won't turn on (even on defrost) and I want to get it fixed before the seasonal rush after the first hot day.
I took it in to a local shop they charged me $80, told me the system is full of R-134a and that I should take it to the dealer as it must be "something electrical".
Thanks,
Frank
Old 05-20-2009, 08:08 PM   #2
MANDD
Autobahn East
Check pressure switch at receiver drier.
Mark.
Old 05-20-2009, 09:42 PM   #3
BmW1819
your are low on frenon and got a leak need to sniff it out take it a shop
Old 05-20-2009, 11:13 PM   #4
summit425
Alpine White
check your heater valve as well. Heater valve was my problem.
summit425 is offline   Reply With Quote
Old 05-22-2009, 05:54 PM   #5
Max_VQ
Max_VQ's Avatar
Thanks for the replies...
Pressure Switch:
On my 01 530, the pressure switch is a pressure sensor (variable output depending on pressure) I could not find what the resistance should be for a given pressure.
Low on Freon:
Nope, First and second shop said it was OK.
Heater Valve:
Interesting.. makes sense, but that was not the problem....
I took it to RMP today and Rocco had the problem figured out in 10 minutes. The DME showed an aux fan fault. The DME won't switch on the A/C compressor if the aux fan test fails.
Rocco gave me a great price on a new aux fan and I will be putting it on in the next hour.
Old 05-24-2009, 10:31 PM   #6
Max_VQ
Max_VQ's Avatar
A/C works great now...
I removed the fogs, bumper, lights, ducting, and air intake. The fan had shorted out and melted (!) part of the wires & circuit board.
There was lots of sand/leaves/crap between the pusher fan and the condenser. I replaced the fan, and checked the fan fuse. the 50A (again!!) had popped. Once the fuse was replaced, and the DME reset the a/c works great.
The new fan must be a different design, as it is 80% quieter than before.
-Frank
