Old 05-16-2009, 09:25 AM   #1
Jonee
Help
Okay guys i go start my car this morning and it cranks but it doesn't turn over I try again and still nothing. I tried 2 minutes later it turns over but then it died . What could the problem be fuel pump maybe ?
Jonee is offline   Reply With Quote
Old 05-16-2009, 12:17 PM   #2
Out of gas, fuel pump, fuel pump relay, ECU, the list goes on. You'll need to figure out if it's getting gas or spark.
Old 05-16-2009, 12:21 PM   #3
Ceeker
most common problem without actually diagnosing from my experience is the fuel pump.
It's on it's way out... I do have one if interested...But you can check as the above mentioned post first. pm me if you want one.
1 90 325is white - keepin
1 87 325i vert -red - keepin
KEEPER 88 5sp Vert 2016
Old 05-16-2009, 02:30 PM   #4
5thseries
biggerthen3
Check the distributor, is it properly pluged in??
Same thing happen to my bros e30
5thseries is offline   Reply With Quote
Old 05-16-2009, 03:00 PM   #5
Ej_Red
How can it crank but doesn't turn over?
Ej_Red is offline   Reply With Quote
Old 05-16-2009, 04:01 PM   #6
SamE30e
SamE30e's Avatar
The engine cranks.. but doesn't start.
85 325 - Turbo M52B28.
Old 05-16-2009, 05:07 PM   #7
Jonee
Okay guys so what ended up happening is I flooded the engine I need to give the car a tune up and everything should be good. I checked for spark and i was getting fuel. What I did was I unplugged the fuel pump cranked then plugged it back in and she fired up. Thank you to everyone for your suggestions.
Old 05-18-2009, 09:34 AM   #8
richie_s999
Car looked good at the meet yesturday, cannot wait till you have the full kit on it and painted.....and keep that front end....it rocks!!!!
Old 05-18-2009, 10:35 PM   #9
Jonee
Thanks Rich . Its gonna take a little while but its a work in progress =D
