Old 05-11-2009, 11:50 PM   #1
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Anybody have transmission input shaft?
Anyone have one lying around? I need to align my clutch and would like to use the real thing instead of a Universal tool.
Please let me know
-Dan
95 530i|Modifications - Work.
ACS_DAN is offline   Reply With Quote
Old 05-11-2009, 11:51 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
I know what you mean, I wanted something similar and ended up using that damn universal tool.
Old 05-12-2009, 12:03 AM   #3
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
How'd it go? were you able to get it alligned properly on the first try? I just wrestled a GM auto tranny off the car and even though the G260 is lighter I still don't want to be messing around with it for too long, My arms are killing me!
Old 05-12-2009, 01:08 PM   #4
Duct_Taper
Sticky
Duct_Taper's Avatar
What pilot bearing diameter? I have a G240 off an M42 almost apart that I could lend you the input shaft from, but it's for a 15mm pilot bearing IIRC.
I also won't be near TO until at least the weekend.
Duct_Taper is offline   Reply With Quote
Old 05-12-2009, 09:05 PM   #5
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Not actually too sure of the diameter dimensions, Don't worry about it. if I can't find one from a 260 I'll just use the tool.
Thanks for the help guys
-Dan
Old 05-12-2009, 09:30 PM   #6
e30_kid89
The Afro-stig
e30_kid89's Avatar
ACS_DAN, that input shaft will work if you're willing to wait to borrows it.
I haven't driven the car much since i installed the clutch this winter but so far very good!
Old 05-12-2009, 09:43 PM   #7
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Cool! Thanks for confirming.
Sending PM to Duct_taper now!
-Dan
Old 05-12-2009, 10:19 PM   #8
Duct_Taper
Sticky
Duct_Taper's Avatar
PM replied.
What is the application you want to use it for? Most earlier cars used a 12mm pilot bearing... according to realoem it looks like the changeover happened late 1990-ish.
From what I can tell it looks like the 260s all used the 12mm bearing.
Edit: Part numbers are 11211720310 for the 15mm bearing and 11211709681 for the 12mm.
Old 05-12-2009, 10:33 PM   #9
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
PM replied.
That confirms it, I'll need the 15mm one.
Thanks for sorting that out.
-Dan
Old 05-14-2009, 09:30 PM   #10
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Anybody?
Old 05-14-2009, 09:31 PM   #11
Duct_Taper
Sticky
Duct_Taper's Avatar
Wait, so you need the 15mm or the 12mm?
I have the 15mm but I think you need the 12mm.
Old 05-14-2009, 09:57 PM   #12
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
I need the 15mm one. I made an error in my postings, this is actually a 250g tranny, so it utilizes the 15mm pilot bearing.
Old 05-14-2009, 09:59 PM   #13
Duct_Taper
Sticky
Duct_Taper's Avatar
Ahhh... well, I can see if I can get the rest of my 240 apart and lend you the shaft from that. I'll be driving through TO on Saturday and Monday.
Old 05-14-2009, 10:06 PM   #14
ACS_DAN
16/F/Cali
ACS_DAN's Avatar
Thanks a lot man, I appreciate it. No worries if you've got other stuff to do and can't get to it.
What time would you be passing through Toronto?
PM sent.
