Old 05-22-2009, 03:18 PM   #16
peanuboy
Dado, will you disable my DRL for me?
peanuboy is offline   Reply With Quote
Old 05-22-2009, 03:41 PM   #17
daveyto
daveyto's Avatar
Transmission adaptation values?
I think this is for an automatic transmission?
Please explain....
daveyto is offline   Reply With Quote
Old 11-01-2009, 09:12 PM   #18
Willycool
PISTOLERO !
Willycool's Avatar
Hello,
I would really like to get a free copy of your Carsoft.
PM me so I can meet up with you.
Thanks,
Willy
Willycool is offline   Reply With Quote
Old 11-01-2009, 10:39 PM   #19
tg07lq
any OBD I stuff? pm me
tg07lq is offline   Reply With Quote
Old 11-02-2009, 12:23 AM   #20
Steve30
Techno Viking
Steve30's Avatar
is it able to reset the driver's behavioral adaptation?
E36 ///M3 S54
???whp E30 coming soon.
Old 11-02-2009, 09:53 AM   #21
daveyto
daveyto's Avatar
MCU controlled Interface for Carsoft 6.5 which is compatible with the original interface. Fully digital line switchings and MCU controlled service reset timing.
Main Functions:
Digital total test: It gives you a complete idea of the overall condition of the car
Digital single test: It gives you detailed information about the appropriate control unit. Stored errors will be shown in a written report. This report has a short info-text which help you to eliminate the error.
Special functions for some models: Including service interval reset, component activation, live data, LCM reading, sync. EWS and ECU, adaptation values, and coding.
.Application list:
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E46 / E53 / Z-3 / Z-8
Petrol Engines : All engines from 1988 to 2004
Additional Features :
- LIVE DATA 1995-2004
- ECU CODING 1995-2004
- ADAPTATION 1995-2004
- EWS Synchronize tion 1995-2004
E30 / E34 / E36 / E38 /E39 / E46 / E53
Diesel Engines : All engines from 1988 to 2004
- ELIVE DATA 1998-2004
- ECU Coding 1998-2004
- EWS Synchronization 1995-2004
E30 / E31 / E32 / E34 / E36 / E38 /E39 / E46 / E53 / Z-3 / Z-8
Brake & Traction : All systems from 1988 to 2004
Airbag : All airbag systems from 1988 to 2004
- ECU Coding 1995-2004
Air-conditioning : All HKL systems from 1988 to 2004
BC / MID : BOARD COMPUTER / MULTI INFORMATION DISPLAY
Instrument Clusters from 1991 to 2004
- ECU Programming 1995-2004
- Change Mileage / Kilometres indication
- Change Time indication 24/12 hours scale
- Change Language indication into 9 different Languages
- Change Temperature indication Celsius / Fahrenheit
DWA : Alarm Systems
Including : ALARM ACTIVATION COUNTER E34
LCM / CCM : ALL LIGHT/CHECK CONTROL MODULES up to 2004
- Reading Original Mileage / Kilometres
- Reading Chassis ( VIN ) Number
E30 / E31 / E32 / E34 / E36 / E38 / E39 / E53 / E46 / Z-3 / Z-8
ZKE / ZVM : All body systems from 1988 to 2004
- Compleete Activation 1988-2004
- Auto-Lock after more than 20KM/h
- Selective opening (for example: driver door only)
EGS : All gearbox systems from 1988 to 2004
EWS : All Immobilize Systems from 1995 to 2004
- Synchronization with engine ECUs up to 2004
E38 / E39 / E46 / E53 / Z-8
CVM : Soft top systems to 2004 E46 (some E36 & Z3)
PDC : All Park Distance Systems from 1995 to 2004
Service Interval : All Service Systems from 1988 to 2004
- Service Light Reset 1988-2004
- Service Management 1995-2004
- Reading of Days since last service
- Reading of Fuel Consumption since last service
- Programming of next Service / Inspection
Old 11-02-2009, 10:36 AM   #22
nachos23
SweetXi
nachos23's Avatar
Originally Posted by daveyto View Post
New to the forum, if anyone needs a BMW diagnostic for their oDB2 compliant car . I can give you one for free. Yes free!!
I am not a mechanic.
I have nothing to sell and only want to help our community out and possibly make some new friends.
I have a working copy of carsoft that I learned to use on my own.The output strangely is in german but its simple enough to translate.
I am located at warden and danforth. If you need a diagnostic just send me a personal note here on the forum and I will do my best to oblige.
Thanks,
Dave
Hi Dave;
Actually a quick question about CarSoft. Where do you source the connectors to allow the OBDII connection to your PC? I can get software...... Thanks in advance..
Bill
Old 11-02-2009, 10:38 AM   #23
daveyto
daveyto's Avatar
I bought mine from ebay...from some guy in China
Regards,
David
Old 11-02-2009, 10:40 AM   #24
daveyto
daveyto's Avatar
Yes I have an ODB1 connection if needed
Old 11-02-2009, 11:55 AM   #25
dil
dil's Avatar
ill take up tht offer
dil is offline   Reply With Quote
Old 11-02-2009, 01:13 PM   #26
daveyto
daveyto's Avatar
Send me a PM with your number and I'll call you.
regards,
Old 01-15-2011, 08:08 PM   #27
sparkybp
Tortures BMWs.
sparkybp's Avatar
daveyto, may i know which communication interface you have purchased to communicate to the e36? I'm looking at purchasing one as well.
Good discounts on all OEM and good quality aftermarket BMW parts. 519-498-9660.
Old 01-16-2011, 03:53 PM   #28
daveyto
daveyto's Avatar
Carsoft...and Pasoft..
Old 01-16-2011, 09:02 PM   #29
tg07lq
obdIItech.com has interface and carsoft, however go on bimmerforums.com and theres an entire seciton dedicated to this, with links to hardware thats proven to work
4cyl autotragic woes...
Old 01-19-2011, 08:53 AM   #30
daveyto
daveyto's Avatar
all software will come with the interface
