Old 05-05-2009, 08:57 PM   #1
BMe30
all by chance...
BMe30's Avatar
used turbo question
what to look for when buying a used turbo with or without an internal waste gate.
thanks
Gone but not forgotten
Old 05-05-2009, 09:31 PM   #2
e30_kid89
The Afro-stig
e30_kid89's Avatar
Some things you can check:
-Depending on if it's a journal bearing or ball bearing, the journal bearing should have some SMALL shaft play and the ball bearing NONE.
-pull the turbine housing/compressor cover and check for any scratches or damaged fins on both inducer/exducer fins.
-also check the compressor housing for excessive oil = leaky leaky.
Old 05-05-2009, 09:38 PM   #3
BMe30
all by chance...
BMe30's Avatar
thanks for the heads up.
would it be worth rebuilding the turbo if what you mentioned is there?
Old 05-05-2009, 11:10 PM   #4
e30_kid89
The Afro-stig
e30_kid89's Avatar
Not really unless it's really hard to find or you're doing it yourself.
