Old 04-23-2009, 10:58 PM   #1
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Few problems after winter
Hey guy after having my 1995 325i stored during the winter as I did bodywork on it and a respray, I've come across a few problems from since before winter and after running it for a few kms.
1. Hood release cable seized near the latch and the hood wont open unless I use a screw driver and pry it up from where the grills are.
2. Passenger side window came off the tracks when it was one of those colder days I had decided to check if it all power options were working.
3. ABS light came on but when I changed the relay it would turn off but then come back on whenever the car heats up to a warmer temperature.
4. Whenever I start the car now, I hear a loud screech for a quick second and it goes away right after.
5. One of the headlight tilting bracket broke while fixing my nose panel.
Please let me know what can be done and quick and easy fixes for all these problems. Thanks
I also painted the entire car black including the rocker panels and bumpers. Before and After pic
3niDaPooh is offline   Reply With Quote
Old 04-24-2009, 12:45 AM   #2
PinkieMoscow
Jumped up G'd up.
Holy shit, where did you keep your car during the winter =S?
PinkieMoscow is offline   Reply With Quote
Old 04-24-2009, 12:54 AM   #3
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Well its been in my garage since october and I only drove it out this morning. The hood problem, hellrot_m3 told me that its most likely the hood latches not releasing and may need changing as well as the cable. The power window was actually my fault cause the temperature was freezing outside so when I started to send the window down, it went off the tracks and I can still hear the motor working if I press the button. Gotta open up the door panel and see exactly whats going on. The abs and starting problem have no clue whats up with them. I most likely will need a driver side headlight unless I can glue it back together.
Old 04-24-2009, 12:19 PM   #4
3niDaPooh
Da Dealer
3niDaPooh's Avatar
All problems are either fixed or will be come this weekend except for the loud screech whenever I start the car and it sound like when you try turning the key and a car is already on.
AND
Now my central locks wont work but the fuses are all good, could it be the module under the passenger dash?
Anyone know what these problems are???
Old 04-24-2009, 12:39 PM   #5
Ceeker
the screeching sound is most likely an alt belt or power steering belt being loose. Once it gets going it tightens up and it's gone. Maybe the tensioner is siezed; typical on e36's.
It's just a bitch to get too. check the belt first for tension and make sure they are in good shape. Tighten and see what happens.
Old 04-24-2009, 05:04 PM   #6
ShortShifter
Sex Wagon
ShortShifter's Avatar
Your window clips broke. You can pick some up at bimmersport for like 5 bucks. Easy to install too.
Originally Posted by alpine86 View Post
Do we really need an Ipad???
Originally Posted by BigD View Post
Only if you have an iVag.
ShortShifter is offline   Reply With Quote
Old 04-26-2009, 02:07 AM   #7
3niDaPooh
Da Dealer
3niDaPooh's Avatar
anyone have a code reader to check my abs light and also this other one that looks like a triangle with an exclamation mark in the middle?
Old 04-26-2009, 10:22 AM   #8
Dr. Flyview
"Mint"
Dr. Flyview's Avatar
The triangle is your traction control (DSC). It will automatically fail if ABS has failed. (I have the same issue).
1998 BMW 328is - summer
1993 BMW 525i - sold
1994 BMW 325i - sold
1992 BMW 325i - gone
sold
Old 04-26-2009, 11:00 AM   #9
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Thanks, now what about my central locking? Many people are telling me that the microswitch in the door is probably bad and not allowing all the doors to lock and unlock. Cause at this point im getting quite fed up of having to do it old school and pull up and push down each door lock whenever needed.
Anyone also know if the central locking module could be to blame and not the microswitches?
Old 04-26-2009, 12:04 PM   #10
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Great now i have another problem, the battery keeps dying after a day of no use and I'm hearing a faint vibrating noise or humming in the back of the centre dash. Could it be that this is causing the battery to die or something else. This is the second battery and it died within a day.
Old 04-28-2009, 12:22 AM   #11
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Ok so far i've gotten the hood to open, the cable is still good but it needed oiling or greasing cause it was dry and the plastic around it hardened up and stopped it from moving at the latch release. The abs light came on bit most likely its because of the worn down pads. The passenger window just came off the tracks so thats an easy fix. Bought a set of headlights from tegboi so thats fixed, as well as a high output alternator from simplycars and gotta pick up a belt from cdn tire so that should fix the loud noise on start up as well as enough juice from my accessories in the car.
Now for my final problem, its either that damn humming/buzzing/vibrating noise i hear from the back of the centre dash or my central locks not working (dont know if its a malfunction somewhere) this is causing my battery to die within a few hours to a day. This problem I really need some help on since i've tried almost everything and cant seem to get it figured out.
Thanks for all the help so far guys. Much appreciated!
Old 04-28-2009, 02:55 AM   #12
Dr. Flyview
"Mint"
That little noise shoudl go away after a while. It's a little fan in there behind the dash that cools off components after a drive (maybe even during not sure). If it stains on that could be your problem.
sold
Old 04-28-2009, 09:57 AM   #13
3niDaPooh
Da Dealer
3niDaPooh's Avatar
but my central locks are still not working even though all the fuses are fine
Old 05-06-2009, 08:17 AM   #14
3niDaPooh
Da Dealer
3niDaPooh's Avatar
Hey guys I would like to know which module control the voltage for the power locks is it the Central locking module or the ZKE IV module that some people recommend?
Old 05-12-2009, 08:47 AM   #15
3niDaPooh
Da Dealer
3niDaPooh's Avatar
anyone know???
