Old 04-20-2009, 04:13 AM   #1
old skoo
1st Gear Red Line
whats a better swap, m5 or m3 ?
hey guys i was wondering, whats a better swap to do, m5 or m3 ?.. and whats needed for the swap. .. i use to own a 318is with e36 3.2 m3 in it, f**king fast son of bitch, but had alot of headaches. im going to build another 1 but i want to know which 1 is worth it.?
old skoo is offline   Reply With Quote
Old 04-20-2009, 06:19 AM   #2
echo
e30 slave
You don't really provide enough info. Which model m3 or m5 engine? That said, the s14, or s50 would be an easier swap (m3 engines) than the larger s38 e34 m5 engine (assuming this is the one you would use, not the newer s62 v8's)
You need to do some reading. An open question like this won't get you many sensible answers. Once you know more about what you want to do, how much it will cost and are serious about it you will get better response to more detailed questions.
echo is offline   Reply With Quote
Old 04-20-2009, 09:27 AM   #3
euro S50 or maybe a turbo M50.
Old 04-20-2009, 09:41 AM   #4
Axxe
Over 9 F**KING THOUSAND!!
Axxe's Avatar
If an S52 was a lot of trouble for you, stay away from BMW M engines.
Old 04-20-2009, 09:51 AM   #5
richie_s999
the origional E30 M3 motor is the best swap for an E30, very pricey motor though
Old 04-20-2009, 09:56 AM   #6
S38 is an extremely expensive engine to purchase as well as make it work and maintain it. Might want to stick with something a little simpler and less finicky, like the m50 or S50.
Old 04-20-2009, 09:59 AM   #7
richie_s999
why not just build an M42 stroker and keep the weight down???
Old 04-20-2009, 10:09 AM   #8
Axxe
Axxe's Avatar
Guys, he already had an S52, and he had a lot of headaches. So my recommendation is to buy a Corolla.
Old 04-20-2009, 03:05 PM   #9
davericher20
black and blue
davericher20's Avatar
I recommend a kia rio
Old 04-20-2009, 04:27 PM   #10
SamE30e
SamE30e's Avatar
85 325 - Turbo M52B28.
Old 04-20-2009, 04:34 PM   #11
FuryriderX
cra.iX.y
FuryriderX's Avatar
^lol
just turbo the m20 (assuming you have one, of course) - have you considered that?
Old 04-20-2009, 06:07 PM   #12
spoony_prelude
Eurowerke
spoony_prelude's Avatar
justin throw a Euro S52 in that bitch and your set!!! or just stick to a US s52. They are a lot easier to maintain and find parts for. It's much harder/expensive to pull off a M5 swap from any generation! although it would be sick as hell!
2011 M3 coupe/moonstone/fox red
Old 04-20-2009, 06:09 PM   #13
spoony_prelude
Eurowerke
He had problems because the guys he took it to knew nothing about BMW's. for ****s sake they hardwired his motor to the harness! Make sure your new e30 never see's its way into that shop again man! Give RMP a call they are a lot closer now and will have it done properly!
Old 04-20-2009, 06:14 PM   #14
SamE30e
SamE30e's Avatar
Who hardwired it?
Old 04-20-2009, 07:11 PM   #15
You already had the cheapest bang for buck swapped e30, and you complained that you couldn't afford it. Try a stock*gasp* e30, it won't bite.
Originally Posted by SamE30e View Post
Who hardwired it?
By 'hardwired', I am betting it was a Motronix swap.
