Old 08-08-2009, 06:15 PM   #16
DINO K
Sauber F1 Team
DINO K's Avatar
5thseries,
once you change tires to a good summer soft compund tire the noise will go away and your car will def feel 10x better, the clicking in between gears is related to Front Engine Rear Wheel drive and that will never change..However, at the light.. put the car in 2nd and then 1st, that usually happens if you stop in the 3rd, 5th gear, so whenever you do so, just go thru the lower gears while your stopped, it will slip right into 1st, and the rpms, thats just cold start related nothin you have to worry about.
DINO K is offline   Reply With Quote
Old 08-08-2009, 06:21 PM   #17
lvan
lvan's Avatar
Originally Posted by doogee View Post
I'm pretty sure BMW's are notorious for having notchy 1st-2nd shifts. Same with it not wanting to go into 1st at stops.
I think so too. When I was learing stick with my E30, there was like once in a while when it just does not wanna go in the first.
Old 08-08-2009, 06:37 PM   #18
DINO K
Sauber F1 Team
DINO K's Avatar
N, 3rd, 2nd, 1st
it's a VW trick ha
Old 08-08-2009, 06:43 PM   #19
lvan
lvan's Avatar
Nah , I just get it going from 2nd. I get scared if I would break the shifter.
Old 08-08-2009, 06:52 PM   #20
DINO K
Sauber F1 Team
DINO K's Avatar
jus try what i said man, you think i havent been thru this? it slides into 3rd n 2nd smooth u have nun to worry about, then 1st will be smooth aswell.. i guarantee no force needed,
Old 08-08-2009, 07:07 PM   #21
lvan
lvan's Avatar
^Yes. I have done it before.
Old 08-08-2009, 07:13 PM   #22
DINO K
Sauber F1 Team
DINO K's Avatar
Non sense damage to transmission
Old 08-24-2009, 09:02 AM   #23
Stephanie
Stephanie's Avatar
As everyone else mentioned above, the runflats suck.
I found a new love for my car (not that i didn't love her already) when I swapped my completely-bald-at-16,000kms-runflats to a set of Kumho SPTs.
The car is quiet and feels a thousand times better... going over a bump doesn't sound like I'm breaking my car anymore and it handles significantly better as well... I find the craptacular compound on the runflats are unpredictable, especially at high speeds.
Black Sapphire Metallic | Coral Red | Brushed Aluminium | 6MT | ZSP | ZPP | PDC | Bluetooth
Shadowlines | Matte Grilles | Aero Lip | BMW Performance Pedals | Smoked Reflectors | LLumar Tint 40%
KW V2 | VMR V710 | Super Sports | BMS JB4 | BMS DCIs | HPF Intercooler | UUC EVO3 SSK | UUC RK7 Shift Knob
Stephanie is offline   Reply With Quote
Old 08-24-2009, 09:12 AM   #24
brunp
Just make sure you have a repair kit in your trunk. My mechanic recommended having the Canadian Tire SLIME Green goop which comes w/ an air compressor, valve removal, repair kit, etc....
Worked like a charm in the 3 weeks before I was able to get my rear-right tire repaired due to a a very small hole caused by a staple....
Paul
brunp is offline   Reply With Quote
Old 08-01-2010, 09:01 AM   #25
bs330i
bs330i's Avatar
I have an 2006 E90, it runs smooth and beautifully, to all the ones thinking these problems are normal..your all just morons
bs330i is offline   Reply With Quote
Old 08-01-2010, 10:11 AM   #26
MarkD
MarkD's Avatar
My wife's 2007 328i runs like a dream, and it also had the runflats when we bought it.. I recently bought some slightly used wheels and tires from an ad here (advertsied as Michelin Pilot Sport 2) and even though the seller said they were not run flats, I think they are as they have a "ZP" on them. They are very quiet and handle quite well. (good enough for my wife who just uses that car to do to work and back)
It sounds like the car discussed here has some other problems with it, besides possibly the run flats.
Old 08-01-2010, 03:00 PM   #27
sexxxybimmer
i think 2006 doesnt come with run flat
sexxxybimmer is offline   Reply With Quote
Old 08-03-2010, 08:13 PM   #28
mstearnsy
You're wrong.
mstearnsy is offline   Reply With Quote
Old 08-03-2010, 08:35 PM   #29
bs330i
bs330i's Avatar
ya they do
Old 08-04-2010, 03:45 PM   #30
Italia311
Italia311's Avatar
They definitely do...
Italia311 is offline   Reply With Quote
